30th November 2018, 19:46
#1
P0400 after cleaning egr
So I was getting the car ready for its mot and gave it a good service
Took off the egr which didn't look too bad but gave it a good clean with oven cleaner
Put it all back together and now I'm getting the EML light
Its plugged in correctly
Strip off and check inside?
I've tried clearing the code but it just comes back
Cdti 150
1st December 2018, 05:13
#2
piston inside sticking, take the top off and check if its moving freely
1st December 2018, 11:56
#3
It'll only move with the electrics won't it?
Does It move when the ignition is switched on?
1st December 2018, 12:51
#4
did you take the black top half off,fixed by 3 small screws
1st December 2018, 14:07
#5
Yep took it all apart, cleaned the inlet where they get goes on
Cleaned the boost sensors well put it all back together and I'm still getting it, the code won't clear at all
1st December 2018, 14:10
#6
1st December 2018, 14:12
#7
I get the spanner light then after a while goes to the EML
1st December 2018, 14:39
#8
make sure the piston moves freely under thumb pressure
#9
1st December 2018, 15:02
#10
Fixed it, I thought I'd spray come cleaner on the plugs in case they were corroded
1 of the pins in the egr was bent
