Planning on running some 10k boost through my cdti 150
Swirl flap bars off and I can't get the flaps to turn fully on their own, hopefully some of this frees them up a bit
Can't seem to find it though
why not use carb cleaner,in a can and a toothbrush ?
Because using the 10k boost i can spray it in the inlet while it's running, there's a guide I'm the how 2's but I can only find 10k boost diesel egr cleaner is this the same thing used in the guide
you can do the same with the carb cleaner..is 10k boost not a chemical solvent cleaner?..I could be wrong as Im a petrol head and have used this method to clean various carbs/throttle plates over the years
https://www.ebay.co.uk/itm/10K-Boost...yG~H:rk:2:pf:0
LOADS OF DIFFERENT 10K BOOST PRODUCTS ON EBAY..
I just read through the 'How too' and it is stated by other users that carb cleaner/EGR cleaner is the same kinda thing..tbh I have used brake cleaner in the past too. its all a solvent.
