Results 1 to 10 of 19
Thread: Bit more engine polishing done
    Regular Member Deadman's Avatar
    earth
    Default Bit more engine polishing done
    When I first picked up my motor the engine bay was......untidy shall we say.
    It's getting nearer to the standard I want it as the weeks go by. I'm a lot happier with it and I dare say I'm proud to lift the bonnet in company now. I've spent two hours on it again today, the cam cover is nearly done, just some further fine polishing to do and it should look like a mirror. I'll tell you what though my fingers are sore!
    Regular Member centaur's Avatar
    Coventry, West Midlands
    Might be a stupid thing to ask for, but would you do a how2 for each bit you have done. I wouldn't mind getting my bay up to half the standard yours looks in so far! Under the bonnet is.........well, not for public viewing!!
    So any tips, etc ?
    Mileage : 000
    That is looking really nice, it is hard work though, but well worth the effort.
    earth
    Hi centaur. Well the first thing is to get rid of all the grime. GUNK (or similar engine degreasant) is good for that, just work it in with a brush then steam clean it off.
    Then all you can do with our engine is clean all the plastic trim (there's a lot of it afterall) and for this task I use good old wet wipes. I find the antibacterial ones the best.
    To get the alloy up to scratch you need to use various grades of wet and dry. However to get a really good shine I use a paper called 'Micromesh'. It goes all the way up to 12000 grade. It's similar to emery paper. You can buy a kit of it (have a look on the net) containing all the grades.
    Start off with 100 grade. That'll take all the corrosion out and leave you with a dull (but nevertheless) polished surface. Then it's just a case of working through the grades. It'll get shinier every time you up a grade.
    Finish off with some Solvol Autosol and you're there.
    I think it's worth the effort, but this has all been done by hand. I plan to use a decent power tool, something like a Dremel to get a 'showcar' standard in time.
    Have a crack at it. It's good for the soul.
    earth
    Cheers Ed.
    Regular Member fellie's Avatar
    Lincoln
    well thats my suspicions confirmed .. you are mad lol..
    looks good, whats the alloy finned part in the middle, looks like a heatsink of sorts ..
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    looks great mate top job done there
    Midlands Mod Shop - NFFC.
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    looks real good.......dread to think what mine looks like
    Thanks for that, Deadman!
    I think this will be my next project.
    ***runs off to find some wet & dry on the net***
    Quote Originally Posted by fellie View Post
    it's a heatsink for the coilpack unit..
  1. More Engine Polishing
    By Leemarksmith in forum Styling
    Last Post: 24th June 2012, 21:38
  2. More Engine Polishing
    Last Post: 24th June 2012, 20:57
  3. Polishing Kit
    By martin_SRI in forum Detailing and Car Care Discussion
    Last Post: 22nd August 2011, 23:08
  4. A guide to engine bay metal polishing
    By bobssignum in forum Detailing and Car Care Discussion
    Last Post: 5th April 2011, 19:51
  5. Polishing The Engine Bay
    By delete2 in forum Detailing and Car Care Discussion
    Last Post: 2nd August 2008, 19:24
