Thread: Sleeping car (and member)
    Regular Member skivandal's Avatar
    Jun 2009
    Dorset
    Default Sleeping car (and member)
    Hi all,
    My beloved Signum 3.2 V6 has been enjoying a blissful sleep in Dorset for the last two years.
    I now fortunately/unfortunately live and continue to live in London but want my Signum back with me, too many good memories, and parking now will allow.
    It has been to the garage today for an MOT assessment as i know a few things need to be done, and this is the summary report.
    • Brake lines corroded and gone. Very long travel on the brake pedal.
    • One headlight dulled to MOT failure point .
    • Broken springs
    It also has a leak of fumes from somewhere to the rear of the engine block.
    I need them to investigate as the fumes at low speed coming into the cabin is too much of a problem. They want/need to spend 4 hrs or so stripping to investigate.
    So have a few question and requests for advice.
    1. Q) On the fumes any ideas on what they might find?
    2. Q) Springs especially front ones seem to be always breaking, are they more durable ones out there? OEs don't seem to last long.
    3. Q) New headlights for 2003 Signum, what do people recommend, angel eyes, black, etc? Considering replacing both, and doing that myself nest weekend?
    4. Q) Cruise control fails, often with use of the indicator, and then cannot be used till the car is turned off and on again. Any ideas?
    Fumes need to be sorted first, so what they find needs to be non-ruinous.
    Car is in Dorset, Wimborne.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Astra Sports Tourer
    Trim : active
    Engine : 1.7cdti
    No idea to fumes but in answer to other questions
    2, I had Eibachs on mine but other members will be along to give other opinions
    3, down to personal choice i swapped my chrome ones for black angel eyes but had to swap the levelling motors over
    4, Could be just a case of removing the stalk and cleaning the contacts but iirc could be the clutch pedal dropping due to worn spring
    Hope that helps
    Aug 2012
    Essex
    Even though mine is the Diesel engine, I was getting fumes coming into the cabin. It was worse on start up and idle rather than driving. It turned out to be the exhaust flex pipe leaking. Once replaced the problem was cured.
    Dont know now if this helps at all.
    Jun 2009
    Dorset
    Quote Originally Posted by Daywalker View Post
    Hope that helps
    Thanks - last time looked at Eibachs and the like it seemed lots of lowered option but few stock height. I like the stock height, so will have another look.
    Its an Auto so will look at the stalk, as i also need to clean up some of the window switch contacts too.
    Jun 2009
    Dorset
    This project moves on very slowly.
    My local garage is being very pessimistic about the fumes, requiring a few hundered pounds to take the engine bay part enough to inspect and then diagnose the issue. They then say that getting hold of manifoild parts is all but impossible (there working assumption of what is wrong).
    Do any of you have suggetion for where i should look for parts for my 3.2 V6, manifolds gaskets etc, and or any other helpful pointers?
    Aug 2007
    Trim : active
    Engine : 1.7cdti
    found exhaust gasket here https://www.ebay.co.uk/sch/i.html?_o...skets&_sacat=0 or you could try autovaux
    Jun 2009
    Dorset
    With great reluctance having to give up on getting my Signum back on the road full.
    Free to anyone that can pick up from Wimborne Dorset.
    Full detail in the South West pages
    https://www.vectra-c.com/forum/showt...12#post2526112
  1. Sleeping with mick
    By Johnsdutton in forum Comedy & Humour
    Last Post: 24th July 2013, 23:47
  2. Now the Astra is sleeping............
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 9th November 2012, 17:12
  3. Top quality sleeping bag.
    By FIL 4822 in forum General items for sale
    Last Post: 11th April 2009, 19:41
  4. Sleeping patterns?
    By JonR in forum General Chat
    Last Post: 3rd January 2008, 14:47
