Results 1 to 10 of 11
Thread: HID question...
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default HID question...
    Why is it that after a year or so that with HID's you can get an intermittent 'bulb out' warning that only goes away when you switch the engine/car off?...
    Turn it on again and its all ok ,till the next time.
    This has happened on 3 cars I know of,2 Vectras and a Honda.
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    i had that on my hids cleaned the conections they where ok after,but still cannot make my mind up hids or nighteyes
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Im happy with the HID light output just the niggle of the warning . I'll try and clean the connections...one day..
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    258 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Which bulb out warning?
    Teapot Tuned 245/300
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    the hid itself...i think..i'll take a look next time it happens..
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    using nighteyes and well pleased and no bulb warning issues either
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    203 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    Did you program your UEC to tell it that it is running Xenons ?
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    36 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    Mine does this every now and again and i found that it is one of the warning cancellers that actually does it... but i also found that cleaning the UEC made this happen less... and sometimes when it does it if I take the key out turn the lights off and start it again and turn the lights back on 9 out of 10 times it turns on... when it doesn't all i have to do is take the canceller off connect the to cables (so it looses it's charge) and connect it back up with the car turned off and the lights off... put it back and it will be function fine for a while mine happens a bit more often than Nikroc's about 2 or 3 months in between but my car is from 2003 so a lot older than his, maybe one of the reasons why cleaning the UEC prevents it for a longer period than before (it used to do it way more often) and probably just like Nikroc i haven't turned the xenon option on (in my case it's due to the not having the right software and cable)
    May 2012
    203 Post(s)
    Mileage : 131,000
    Switching the Xenon option on would mean no need to use cancellors and no more bulb out errors
    Apr 2016
    Ipswich
    36 Post(s)
    Mileage : 140000
    I know just don't have the software and cable for it yet but it is on it's way.. when i have it it'll be changed.
  1. Odd question
    By vmb2722 in forum The 'Off Topic' room
    Last Post: 16th April 2015, 09:57
  2. BID to GID question
    By Shaddex in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2014, 00:40
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. tid question?
    By big rich in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2008, 18:14
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
