Likes Likes:  1
Thread: Signum Drivers side leak
    Nov 2018
    Stockport
    Trim : SE
    Engine : 3.0TD
    Default Signum Drivers side leak
    HI,
    I have a drivers side leak... I know the scuttle issue and have cleared the drains.
    I was in a car wash and mist started to come out of the vents (aircon was on as it was a hot day)
    On the way home realised the carpet was swimming.
    So I cleared the scuttle again.
    Water was still getting in and I have spent a few months drying it out, Still really swamped. And I can't find the leak.
    The 2ndary issue... The fan has stopped working - all 7 speeds. Therefore now driving around in a swimming pool I can't demist or get dry.
    I have pulled up the carpets and looked for the leak with a hose going all over the car.
    I did spot this - a foam washer that was sodden but no real water ingress.
    Any ideas?
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    235 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Isn’t that the location of the heater matrix? Have you been loosing coolant at all?
    Also how you park and has this only happened when it’s rained?
    Teapot Tuned 245/300
    Nov 2018
    Stockport
    Trim : SE
    Engine : 3.0TD
    Hi, sorry been away, so apologies for slow response.
    No coolant loss.
    Parked on driveway outside - its flat.
    Its only on the drivers side...
    other than the scuttle issues is the another way for water to get in to the drivers side.
    The boot is dry, doors seem dry...
    SO the first time I noticed the issue was in the very dry summer after going through a car wash. How could water get into the heater matrix?
    thanks
    Nov 2018
    Stockport
    Trim : SE
    Engine : 3.0TD
    It's a Signum V6 Elite Manual (quite rare I believe) that just needs some love I think...
    Full Member
    Nov 2014
    Sweden
    Vehicle : Vectra C estate+hatchback
    Trim : Enjoy/OPC line
    Engine : Z20NET
    Year : 06&08
    Hi, take a look at the aircon drainage, I had the same problem and found that the drainage was blocked by gunk. Just put a screw or something into it and see if water starts to pour out.
  6. Likes Dog_Book liked this post
  7. #6
    Oct 2013
    Derby
    235 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by 72Cookies View Post
    Very, meet up with me for a little tweek will make it go better
  8. #7
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    237 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    One of our signums has the same issue and as yet I've failed to find the source.
  9. #8
    Full Member
    Jan 2016
    buckley
    5 Post(s)
    Vehicle : vectra
    Trim : design
    Engine : 1.9 150 diesel
    Year : 56
    have you checked the roof rails if it has them,as the fixing rivets become loose and let water in
  10. #9
    woodbridge, suffolk
    237 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by paula9568 View Post
    No roof rails on ours, not sure about the OP
  11. #10
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Have you checked scuttle bung on drivers side.
  1. Oil Leak from front drivers side
    By lofty in forum Engine & Drivetrain
    Last Post: 29th July 2013, 18:30
  2. Signum front fog light drivers side
    By Niall83 in forum Parts for sale
    Last Post: 21st December 2010, 17:54
