Results 1 to 10 of 11
Thread: Is something missing?
    Default Is something missing?
    I just had to change a nearside headlight bulb and noticed that my battery isn't bolted in..... its able to slide around in the battery bay. Also it looks like something is missing from the front of the battery box. Can someone with the same as mine please have a quick look at theirs and let me know if its right?
    3.0V6CDTi
    Thanks!
    morton
    i dont own one ! but i'm sure the battery should'nt move about !!
    Mileage : 000
    Whilst mine is a bit different to yours, I don,t think the battery should be able to move about, I thought it was an MOT failiure if it was not secure.
    morton
    thats true ! it is !!
    I thought it was, so what holds yours in? I have an empty bolt hole, looks about M6 or M8 thread but nothing in it. Its probably always been like that since I bought it!
    Mileage : 000
    There is normally a plate that is bolted to the base of the Battery stand the lip in the plate rests on the ledge on the bottom of the Battery. I would go to your local VX dealer and get them to look at the "screen" and see what parts you are missing, they then should be able to order them for you.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I've just had a look at mine & the battery has a moulded extension at the bottom of each end & this is held under a lug in the battery box. I'll try to take a picture
    Thanks mate. Also if you look at the second pic you can see that the main cables that go to the battery seem as they should locate into some sort of clip? What does yours look like?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    This is from a 2.2 petrol but they all have the same fixings.
    You can see a plate held down by the missing bolt you were on about just above my thumb. HTH
    Yeah that helps, thats deffinetly missing! Probably removed by a top quality technician! Although my battery is somewhat bigger
    Anyone have any idea of whats missing with the cable routes?
  1. Something missing?
    By Lee_gsi in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 19:23
  2. What am I missing
    By webmonkey in forum Engine & Drivetrain
    Last Post: 18th July 2008, 22:47
  3. Missing - Please Help
    By LJ sxi-nav in forum Comedy & Humour
    Last Post: 7th July 2007, 14:41
  4. Is this why it's missing?
    By armstma1 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2007, 11:56
