16th November 2018, 17:42
#1
Marietra
Hello. I am a new member. I own a 2007 1.8 vectra, with the vehicle running the brake lights operate properly. When I have the rear demister on and the front demister on the brake lights come on when I press the pedal, but when I let go of the pedal they stay on. If I turn one of the demister off they take a few seconds to go off after I have released the pedal. If I turn off both demister the brake lights work properly. Has anyone come across this problem and if so how did they cure it.
many thanks
16th November 2018, 19:35
#2
Welcome!
Not heard of this before myself, but there may be someone on here who has. This place is a world of knowledge and helpful advice and also a great place to get wallet emptying tips!
17th November 2018, 04:27
#3
Personally, I'd put the post in the vectra section......you might get more viewers.
Post Thanks / Like - 0 Thanks, 2 Likes
18th November 2018, 10:18
#4
Disconnect the battery for 30 minutes, make site you have the radio code, try again....
19th November 2018, 12:10
#5
Originally Posted by
fatfred
OP says it's a 2007 model.
Radio code won't be necessary as the car is full canbus.
19th November 2018, 23:39
#6
Big Dave
Then I apologise, but i would rather be over cautious than give the op another problem.
20th November 2018, 11:33
#7
The only problem he should incur disconnecting the battery is losing the one touch function of the elecy windows. Instructions to re-establish them are mentioned in the handbook.
