Thanks Thanks:  1
Likes Likes:  1
Thread: Different size rims on same axel
    VIP-Member
    Jul 2018
    BIRMINGHAM
    Trim : Life
    Engine : Z19DT
    Year : 07
    Default Different size rims on same axel
    I'm about to fit my new refurbed 17" alloys to replace my 16" steel wheels.
    I hadn't put any consideration in to the fact that the spare wheel I've got is 16" so now I'm stuck. I can't find a 5 x 110 steel wheel in 17" so I think my options are to get another 17" alloy (which cost almost as much as a set and I'm not sure would fit in the boot) or to put the same size tyre on the 16" spare wheel.
    Would the second option work, it obviously wouldn't be on the car for more than a week or so whilst the original is fixed but could I have a 215 50 17 on the same axel as a 215 50 16?
    North West - RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    87 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    I have 235/35/19's on the snowflakes, the factory alloy, yet there's a space-saver in the boot.
    if you HAVE to have the spare on, make sure it's on the back!
    because........SIGNUM!
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by bonehead View Post
    +1 for this.
    Best practice is if you get a puncture on the front, swap a correctly sized wheel from the rear to the front, and put the space saver/smaller wheel on the rear. Just keep your 16" spare and do this if required.
    Sep 2014
    uk
    Vehicle : vectra C sri estate automatic
    Trim : sri auto + design auto x 2 1/2
    Engine : 1.9 cdti 150
    Year : 08/07
    My 2008 1.9cdti sri estate has 17" alloys 215/50/17 as standard and it was supplied with a 15" space saver ( it's madness ). On the estate you can't fit a fullsized 17" alloy in the wheel well so as i had a vectra B as well which had a full size 16" spare with a 195/?/16 i tried this on front and back wheels and it's a very good fit both in tyre height and offset and clears the standard front brake caliper.Also as a added bonus it just about fits in the estates wheel well. If i were you i would look online at the tyre heights charts and fit a tyre to your 16" steel rim that is closest to your 17" tyres in height.I think it should fit in your wheel well ok if yours is a hatchback.
  5. Thanks Drogen24 thanked for this post
    Likes Drogen24 liked this post
  6. #5
    11 Post(s)
    Remember that the sole purpose of a space saver is to get you to the nearest garage to enable you to get the damaged tyre repaired or replaced. It is not meant to be used as an everyday wheel and tyre.
    You should also moderate your driving style and not go above 50 mph while the SS is fitted.
  7. #6
    Sep 2014
    uk
    Year : 08/07
    [QUOTE=Big Dave;2505268]Remember that the sole purpose of a space saver is to get you to the nearest garage to enable you to get the damaged tyre repaired or replaced. It is not meant to be used as an everyday wheel and tyre.
    You should also moderate your driving style and not go above 50 mph while the SS is fitted.[/QUOTE
    Thats how it should be with a ss but how many have i seen being thrashed on front axels ,loads . My thoughs are i would sooner run with my 16" full size on a wet sunday night 300 mls from home and fully loaded ,running at moderate speeds rather than a 110 15" ss and trying to find a tyre fitters that is open in a unknown part of the world. What gets me is many cars can carry a full size wheel in the wheel well or cradle but are supplied with a ss.
  8. #7
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Buy a new car!. Spend 26 K and get a tin of f ing spray. ...
  9. #8
    11 Post(s)
    Quote Originally Posted by autov View Post
    People want cheaper road tax and also weight saving, which is why the manufacturers fit SS's in the boot, or even a can of glue and a mini compressor (or so they tell us).
  10. #9
    Mar 2017
    Hastings
    Trim : Exclusiv with Plus Pack
    Engine : 1.8i VVT
    [QUOTE=autov;2505314]
    My sentiments exactly. The guy that owned my car before me threw out the space saver and replaced it with a 16" steely.
  11. #10
    Sep 2014
    uk
    Year : 08/07
    People may want cheaper ved but i don't think anyone thinks about how heavy the car is when there looking to buy.So why did GM fit 15" spacesavers to both of our vectra c designs with 16" alloys when you could fit a full size 16" steel wheel in.? Probably because they could ,it is cheaper ( more profit ) ,they could because there allowed to ( theres no law against it) .But why have a large wheel well that takes a full size wheel when your only going to supply a ss ? probably because in some countries you have to have a full size wheel.
  1. axel stands
    Last Post: 17th October 2010, 17:05
  2. Where to put axel/jack stands?
    By hkp_octb in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 14:49
  3. found some rims....please let me know what tye size i need????
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2009, 18:42
  4. axel weight and lowering springs
    By animal22 in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2009, 04:48
  5. what size tires are on the VXR 19" rims..?
    By Rockster in forum General Chat
    Last Post: 28th September 2007, 18:01
