Thread: Weird Central Locking Issue
    Dec 2012
    Devon
    Default Weird Central Locking Issue
    Afternoon All, My preface lift Vectra C's central locking is playing up, the auto central locking is working backwards! When I am in the car with the key in hand or pocket but not in the ignition or right outside it will auto lock the doors, however when I leave the car it stays open and doesnt autolock, Ive accidentally left it overnight unlocked and it didnt lock!
    How can I get my auto central locking working correctly again?
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    The first thing i would do is battery off for 30 minutes but i can't see how old your car is so don't know if it's full or half can.
    Dec 2012
    Devon
    Its a preface lift 2005, I think its half can.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    38 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    first thing i would do is switch the contact to first position than have press the unlock button for 10 seconds wait for a beep, turn the key back to off, than on again and repeat it for the unlock button... this should re-register the fob and by doing so it should react properly again.. if it doesn't than i would take the battery off for 30 minutes and if yours is a half canbus car with the OEM radio only do that if you've got the radio code ( it should be on the carpass in your booklet)
    12 Post(s)
    The autolock only works if you've unlocked the car, but not opened any of the doors or boot.
    The only other autolock function is the one where the doors lock themselves once you drive off and go above approx. 5 mph.
  1. Central locking issue
    By alan p in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2017, 23:47
  2. Another central locking issue!
    By musicpug405 in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2015, 13:50
  3. Weird Central Locking Fault
    By Clif in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2015, 17:36
  4. Central locking issue?
    By Slammedorion in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2012, 18:18
  5. Corsa C - Weird central locking problem
    By damers2000 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 17:28
