Thread: "Spanner"Warning light on...Occasional fault
    Apr 2017
    cannock
    Engine : 1.8 Petrol VVT
    Mileage : 81345
    Default "Spanner"Warning light on...Occasional fault
    Hi its happened three times now...Spanner warning light flashes and operates immobilizer Switch it off and on again and alls well again till next time Any ideas as to what I should check out? Thanks
    Aug 2016
    Croatia
    Trim : Cosmo
    Mileage : 100000
    Best approach is connect car to diagnostic tool such as tech2
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    13 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Read the stored codes. Only way to know what's going on really
    Apr 2008
    West Yorkshire
    Quote Originally Posted by vectraman63 View Post
    Try using your spare key in case the transponder is giving up.
    Regular Member stuwieb's Avatar
    East London
    Any other ideas for this??
    I am Getting this issue but the light isn't always on.
    My mate connected a diagnostic tool but no errors were found. (note the light wasnt on at the time, it's intermittent)
    Also I only have the 1key so can't try a spare as surgested.
    Dec 2013
    Bristol
    13 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Quote Originally Posted by stuwieb View Post
    There are tools and there are tools!
    What did your mate use to read the codes?
    If you don't find out what is causing it you could spend a hell of a lot replacing bits for the sake of it.
    Even a cheap bluetooth unit from Ebay and a smart phone will give you an idea of the code. Put one in the car, wait for the next issue, read the codes.
    Then you can address the problem
  1. "check light" fault message
    By danhariga in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 15:50
  2. 1.9 CDTI 150 "spanner light"
    By flyinggazza150 in forum Engine & Drivetrain
    Last Post: 14th November 2010, 14:36
  3. "Spanner Light"
    By elkesprint in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 13:08
  4. Spanner light on dash - "self test"
    By 24vElite in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 20:21
  5. The "flashing car picture with spanner through it" light
    By Big Dave in forum Engine & Drivetrain
    Last Post: 9th February 2008, 04:33
