Results 1 to 3 of 3
Thread: Upper control arm - strange problem
    Jul 2014
    Coulsdon, Surrey
    Vehicle : Vectra SRi T estate
    Engine : 2.0 Turbo
    Default Upper control arm - strange problem
    I recently had fun changing the lower control arms (as described on another thread) and, along with the troublesome toe in/out bolts, I had to cut off the large bolt from that arm to the hub after the nut seized on it. Had a bolt in the shed that sufficed as a temporary replacement but got the proper replacement bolt yesterday so fitted it. After lowering the car back to the ground I grabbed the top of the rear wheel and pushed/pulled to check for play.
    Was disappointed to find quite a bit of play in the upper control arm to hub joint. I reached through the wheel and could feel the movement in this bushing. (Note that this was before driving the car anywhere - it was just after lowering it off the jack).
    So, I ordered a new control arm (with new bolts this time; I've learnt that lesson!) which was supposed to arrive today but doesn't look like it will :-(
    Drove the car yesterday evening and checked for play again this morning. Strangely, there seemed to be no play whatsoever! Jacked the car up and lowered it back down again and the play returned but I'm sure it will be gone again after a short drive once the suspension has settled.
    Any idea what could be going on here?
    Jul 2014
    Coulsdon, Surrey
    Engine : 2.0 Turbo
    Still waiting for the new arm - so much for next day delivery! Have had the delivery charge refunded and apparently it should now arrive on Sunday (hmmm).
    Jul 2014
    Coulsdon, Surrey
    Engine : 2.0 Turbo
    New upper arm fitted and no play anymore Could move the larger bush (ball joint?) within it's mounting slightly by hand once the arm was removed. Strange how it only showed symptoms of failure when just lowered off jack/axle stands.
    Not such a difficult job second time around - quite easy really with around 500mm of extension bars to get to the inner bolt.
  1. Upper control arms
    By jamiedvvt in forum Suspension, Wheels & Brakes
    Last Post: 24th March 2014, 13:54
  2. Upper control arm bushes
    By witty in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2013, 15:06
  3. upper control arm?
    By jimmyred in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 13:42
  4. Rear upper control arm
    By GSiFan in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 11:54
