Thanks Thanks:  6
Likes Likes:  5
Results 1 to 10 of 30
Thread: Worcester Bosch 24iRSF HELP!!
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    23 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Worcester Bosch 24iRSF HELP!!
    Long shot BUT you never know....after the combi boiler overheated I now have no hotwater. The system was low and is now re-filled and semi working. The reset button was ..erm reset .
    The central heating comes on ok and I do then sometimes get hot/lukewarm water...BUT without the central heating being on I get nothing.
    No signs of life at all. Power light,on the boiler remains constant and does not blink to indicate any faults(tbh not sure if it's supposed too).
    So washing the potts is fun atm and as for having a bath....
    ANY helpfull diy suggestions???
    Regular Member CLUB04's Avatar
    Jan 2014
    Watford
    5 Post(s)
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    Quite possibly your motorised valve at fault
    If you can provide me any info on the boiler (serial number, G.C. number) I can ask about (I work in a plumbers merchant) and see if I can get a decent diagnosis for
  3. Thanks nikroc, big jon thanked for this post
  4. #3
    Nov 2007
    DERBY
    23 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thanks for the response..the boiler was fine before the overheat..like I said still kinda supplies hot water if the heatings on but nothing at all if its off..no noise or any life when on'demand'..
    Its a Worcester 24iRSF Combi...G.C. 47 311 37
  5. #4
    Jan 2014
    Watford
    5 Post(s)
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    I have called Worcester Technical for you
    They say there could be a couple of different things causing your issue
    I have the direct number for their technical - 0330 123 3366 - and have asked that you call them when you are in front of the boiler as they have some tests you can do to diagnose which part is faulty.
    Hope this helps mate. If I can do anything else, just let me know
  6. Likes big jon liked this post
  7. #5
    Nov 2007
    DERBY
    23 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Thank you so much for your intervention,wouldnt I need to give then a CORGIE number or some form of ID..Im a retired nurse with a can do attitude to having a go...
  8. #6
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    259 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by nikroc View Post
    No just call them
    Teapot Tuned 245/300
  9. #7
    Nov 2007
    DERBY
    23 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    ie not a plumber.
    I have previously tried calling for help BUT was refused as not a registered plumber..confused.com
  10. #8
    Jan 2014
    Watford
    5 Post(s)
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    For the tests they can do over the phone you don't need any I.D. just call the technical number and they will helpful. Worcester's after sales are pretty good and the technical are too
    That will be only to identify what is wrong and for them to (hopefully) give you a part number for what you need to replace
    Technically (in the eyes of the law) you would need to be a registered gas installer to change the part. You need to be even to remove the outer casing, technically!
    However, if they give you a part number, PM me and I will speak to a branch of the group I work for that is nearest to you and get you a price, availability and maybe even a good local engineer that the branch know and trust to give you a quote (have to be careful what I put out publicly, so have to give 'proper' advice lol)
  11. #9
    Nov 2007
    DERBY
    23 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I tried...refused to walk me through any tests...said id need somebody to test it..e suggested it would be the circuit board..
  12. #10
    Jan 2014
    Watford
    5 Post(s)
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    Bug*er
    They said that wouldn't matter
    Sorry, I didn't think that would happen
    If it is a PCB, the part number is 87161463000 (manufacturers part number)
    If that helps!
  1. anybody with tech2 in worcester?
    By ScottyV6 in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2011, 23:20
  2. Worcester 23/11/09 5pm
    By Birchy63 in forum The 'Off Topic' room
    Last Post: 27th November 2009, 15:13
  3. Baylis - Worcester
    By mc_orion in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 30th July 2009, 11:58
  4. Worcester Area
    By taffy in forum The 'Off Topic' room
    Last Post: 6th April 2009, 10:21
  5. 2 x Black SRI's Worcester
    By Ben_ in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 6th April 2009, 09:47
