Thread: New Clutch Spring
    Regular Member Vec-6289's Avatar
    May 2007
    Cirencester (Days off) Lyneham (Work days)
    Default New Clutch Spring
    I have been having a problem with my cruise control (it wouldn't engage) and have diagnosed the problem to the clutch spring being too weak to bring the clutch pedal fully back to it's correct position. When i pull the pedal back with my foot, the cruise control engages and functions correctly.
    I am hoping to get it changed under the warrenty i have with the car, but in case they say no, does anyone know how much it might cost me to have the clutch spring replaced?
    [Ex]Admin Duncan's Avatar
    The part isn't too expensive, and it's a simple job from what I understand, so if they don't do it under the warranty you have you could probably do it fairly easily yourself.
    Regular Member stickshift's Avatar
    North London
    I've been intending to get mine sorted for while. I didn't know there was a quick fix/mod until saw this thread a few months ago: http://www.vectra-c.com/forum/showth...ghlight=spring
    May 2007
    north wales
    I had the same problem and to it to my local Vx dealer.£7 for the spring and about 30 mins labour.The mechanic had to get help to fit the spring so doesn't look good for fitting it yourself(or maybe he's a **** mechanic!).C/C still didn't work after it was fitted and Vx salesman just shrugged his shoulders and said book it in again!(More money please).After 4 days it started working(Weird!).
    Pete.
    May 2007
    Well, mine has started working now anyway. Occasionally it doesn't, but most times it does now, and when it doesn't i just move the clutch with my foot and it is fine.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i had the same done.
    they put a different spring on mine, as the old style spring snapped in my car and wouldnt return the pedal to the top.
    i went to vauxhall to buy the new spring, they told me that they had upgraded the spring and that they would fit it under warranty for me. my car wasnt under any warranty at the time. im guessin they did it under warranty due to there being an upgrade for it.
    Northamptonshire
    just took my motor in today for a new clutch spring all done under warrenty on a recall notice, THE RECALL NOTICE RUNS OUT TOMORROW! Sept 30th 2007 so not long if you havent sorted it yet!
    Regular Member alid32's Avatar
    Lancashire
    I had this problem on my previous vectra.....never bothered to take it down to Vx....too much like hard work!
    Just used to push the pedal up with my toes
    South Yorkshire
    Hi,
    Just had my car serviced and asked them to look at a noisy clutch. When I press the clutch pedal my car ticks over as smooth as anything but on release it sounds very clattery. As my warranty runs out today, I asked them to investigate and it was found to be a faulty Flywheel which they have agreed to replace under warranty.
    Ive had some problems with stutturing etc so wondering if this could be a linked problem.
    Hope this helps.
  1. Clutch spring mod...
    Last Post: 24th November 2015, 17:28
  2. Clutch Spring
    By Ian T in forum Bodywork & Interior
    Last Post: 19th November 2014, 01:19
  3. Clutch pedal spring.
    Last Post: 1st May 2012, 00:06
  4. Clutch spring kit
    By KEV E in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 17:02
  5. Clutch Spring
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 15:39
