Likes Likes:  3
Thread: Throffing in water header tank
    Apr 2018
    Cornwall
    Vehicle : Signum 1.9cdti
    Engine : 1.9
    Default Throffing in water header tank
    Hi all I come across a problem in my signum cdti 120 bhp.124k Miles.
    i was cruising at 80mph and my water light come on dash so I pulled over to see that there was throffing in the header tank.the temp gauge had stayed the same like it always does and the water was warm as I could put my finger in it.there is no oil contamination there but am I right in thinking that there is possibly exhaust gasses mixing in there from the head leaking.
    i turned the car on and of and drove another 20-30 miles no problem and stopped to check the water and everything was back to normal with no throffing and temperature staying the same.i havenít lost no coolant and no pressuring either.
    could it be rabies 😆
    anyone had similar or no of anything.im doing the sniff test at weekend to see what is on but wonít bother if itís head gasket.
  2. Likes soulman liked this post
  3. #2
    Jan 2008
    110 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
  4. #3
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Oh dear sounds ominous
    Teapot Tuned 245/300
  5. #4
    Apr 2018
    Cornwall
    Engine : 1.9
    Frothing
  6. Likes RBH liked this post
  7. #5
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    244 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Most likely the EGR cooler has ruptured, allowing exhaust gasses into the cooling system. However if the coolant pump hasn't been changed lately it's well worth checking and replacing it (along with the timing belt), because it has been known for the impeller to come loose from the shaft.
    If it turns out to be EGR cooler, choices are to fit a new EGR cooler, or fit a blanking plate at both ends of the EGR circuit and disable the EGR system in mapping.
  8. #6
    Apr 2018
    Cornwall
    Engine : 1.9
    Still ongoing at the moment.it comes and goes.i have blanked the egr on one side.im getting no reading on the temp gauge.would this be a reason for it to be playing up?
  9. #7
    Apr 2018
    Cornwall
    Engine : 1.9
    Think I may of solved it.you wouldn’t think it but after driving a 80
    mile round trip I had no froth.i replaced the header tank cap thinking for the sake of £4 from
    gsf what harm
    can it do and it worked.it hasn’t lost no coolant either.im replacing water temp sensor to so fingers crossed it has cleared.
  10. #8
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    13 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Quote Originally Posted by Ash-signum View Post
    gsf what harm
    Quite possibly the system was losing pressure hence the water boiling. Water under pressure boils at a higher temperature hence the reason for a pressurised cooling system.
  11. #9
    Oct 2013
    Derby
    247 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by fatfred View Post
    Physics
  12. Likes fatfred liked this post
  13. #10
    Apr 2018
    Cornwall
    Engine : 1.9
    The water didn’t boil.
  1. Oil 'on' water in header tank
    By lee gsi in forum Engine & Drivetrain
    Last Post: 17th January 2015, 18:39
  2. Insignia Oil in water header tank
    By Hammy in forum Insignia car chat
    Last Post: 8th December 2014, 13:43
  3. water returning to header tank
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2013, 23:43
  4. water in header tank bubbling....why ?
    By manimal in forum Engine & Drivetrain
    Last Post: 28th September 2010, 18:41
  5. Header tank.
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2008, 21:41
