Thread: Spark Plug check Z22YH engine
    Full Member
    Luton
    Default Spark Plug check Z22YH engine
    Being (very) `old school' I thought I would check the plugs at 17k miles on my Signum 2.2 `Direct' facelift model - Nov 2005 build.
    I was concerned that disconnecting the wiring loom plug on the ignition module that sits above the plugs might upset the CanBus .....
    However, you do not actually need to remove the loom plug, as I found out.
    So ..... gently pull the long ignition module cover from the space between the camshafts. There are 3 pairs of claw type plastic retainers, and it is just a case of gently working the cover upwards using your fingers.
    This will expose the ignition module, which is retained by 4 hex headed bolts
    (10mm head size ) - unscrew these *.
    Gently pull the ignition module upwards by hand, working along the module from the offside end. The resistance will be `rubbery' as you are pulling the spark plug boots from the spark plug electrical 'nipple'. The spark plug boots are flexible from half way down, so gently pull pull the module up, tilting it up at the car offside end, and carefully lay it to one side.
    You can now remove the spark plugs for inspection - mine were BERU 14FGR-8DQU7and seemed fine. However, they did `squeak' for the first quarter turn as I unscrewed tham, so I put a little WD 40 on the threads when I put them back in - just snug them up. If you do use a torque wrench de-rate the torque setting if you do lubricate the threads. (30-50 % ??). I prefer to rely on `feel' for threads in alloy myself !
    (* As a postscript, there is a copper earthing bar connected to the windscreen side/near side) ignition module retaining bolt. I suspect this is for screening, but if you are concerned, loosen the bolt, leave it in place in the ignition module, and use a length of electrical wire and croc clips to earth it down to the body or engine. I didn't bother though)
    Hope this helps.
    Omega2498
    ijk571
    Guest
    sorry to dredge another old thread, but how many turns would you say (once hand tightened) with the socket would you say to tighten the plugs? I am paranoid about over doing mine when I change them in a couple of weeks.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    just so they are tight enuf dont go silly with them mate
    Regular Member AndyMaz's Avatar
    Aug 2011
    Kent
    Just nip them up at the end.
    ijk571
    Guest
    say 1/4 to 1/2 a turn?
    11 Post(s)
    Quote Originally Posted by omega2498 View Post
    I realise this is an old question, but the plugs don't require changing until 80,000 miles or 8 years (whichever comes sooner).
    They don't need regapping either as you should never attempt to regap multi electrode spark plugs.
    ijk571
    Guest
    It always used to be about 30-40k on my previous cars. I realise its now 80k with these plugs but if it used to be a lot less, there must have been some loss of performance/degradation within the plug over time. I do lots of short runs so I guess at 32k it cant hurt?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by ijk571 View Post
    Ive just changed mine, at 60k and there has been no difference in performance or mpg. Same as you, lots of little runs.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    just changed mine cars only done 44000 no diffrence at all
    ijk571
    Guest
    Perhaps I'll wait another 10000 miles...
    No, wait hang on that will be in about 2 and a bit years time.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. Spark plug replacement 2.2.direct (z22yh) advice.
    By Dobs in forum Engine & Drivetrain
    Last Post: 12th February 2012, 18:32
  3. Z22 YH Engine Spark plug change.
    By floppus in forum Vectra C / Signum Troubleshooting
    Last Post: 5th October 2011, 13:29
  4. Spark Plugs - Z22YH
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 11:45
