Likes Likes:  3
Results 1 to 10 of 11
Thread: Burned out plug
    Regular Member JagRigger's Avatar
    Norfolk
    15 Post(s)
    Trim : Design
    Engine : 1.8 VVT ( No2 ! )
    Mileage : ... 293 k
    Default Burned out plug
    I put this on the 'other' social media site from the mobile, but now I'm sitting comfortably I'll post it here too.
    My trusty old 1.8VVT pulled away a bit hesitantly last night, then got worse over the next 5 miles or so, then up pops the engine management light. Missfire cylinder 2 ( pretty obvious I was running on three by then )
    Limped home, expecting it to be the coil pack ( always has been with similar symptoms in the past, and always pot 2 on both my Vectra and the wifes 1.8 Astra )
    Pulled coil and plugs and found this
    Now those who know me, know I mechanically pamper the old girl - service every 10, plugs at 30 ( although they should do far more ) but I've never seen this before. The other plugs were all a lovely golden brown as I'd expect.
    Why did it do this ?
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    This is a bad one that possibly has fallen in the factory during packaging and picked up and put in the box....
    I would look down the cylinder with a scope just to check there is no damage to the top of it because it might indicate a bigger problem... Bearing gone on that cylinder.
    If that all checks out just replace it and keep driving
    Apr 2013
    Luton
    Vehicle : Vectra C Hatchback
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    Bl**dy Hell!
    How long/miles had it been in?
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    Quote Originally Posted by vowner View Post
    Bl**dy Hell!
    Try reading the OPs post again. He mentions "service every 10, plugs at 30" One would presume he means 10,000 and 30,000 miles.
    Plugs in my old 2.2 Vectra weren't changed until 86,000 miles (Vx recommend every 80,000 or 8 yrs). they still looked like new when taken out.
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    So the plugs could have been in a few miles or nearly 30,000 miles, thats why I asked the question. ie how many miles had the plugs done?
    Oxfordshire
    13 Post(s)
    Engine : 2.0 CDTi
    Year : 2013
    Apologies, I can see where you're coming from now
  7. Likes nikroc liked this post
  8. #7
    Norfolk
    15 Post(s)
    Trim : Design
    Mileage : ... 293 k
    26k
  9. #8
    Apr 2013
    Luton
    Trim : Exclusive
    Engine : 1.8 VVT
    Year : 07
    No worries ta Dave
    26K thats worrying, I used NGK last change, not saying they are better, guess there can always be a random, unexplained, fault.
    Have you had a look in the cylinder Jagrigger? Hope its OK.
  10. #9
    Norfolk
    15 Post(s)
    Trim : Design
    Mileage : ... 293 k
    Ran a compression check and it's similar to the others three, so assuming nothing serious
  11. Likes northpole liked this post
  12. #10
    Apr 2016
    Ipswich
    93 Post(s)
    Year : 2003
    Mileage : 140000
    In that case replace it or all of them and keep on driving! The bit is small enough to be blown out of the exhaust anyway.
  1. UEC burned out - how to change UEC?
    By mfa_sk in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2017, 19:15
  2. My Work burned down, this does kinda suck
    By Jebus in forum The 'Off Topic' room
    Last Post: 21st February 2014, 20:38
  3. Is Your Home Insured? House burned down today.
    By 67688c in forum The 'Off Topic' room
    Last Post: 16th March 2009, 22:54
  4. burned up a nissan micra!
    By izonoky in forum General Chat
    Last Post: 27th March 2008, 21:59
