5th September 2018, 16:29
#1
5th September 2018, 16:57
#2
Have a look in the generic drivetrain section for auto box as the auto box isn’t engine specific. I’m sure many have done it and you will hopefully find your answers there. I was lucky when I did my NS shafts as I expected oil to come out so caught it in the drip tray.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
5th September 2018, 17:00
#3
Cheers mate. Just out of interest. Is the fluid that came out ATF or gearbox oil? or are they the same thing in an auto?
5th September 2018, 17:47
#4
If you have the AF40-6 (AWTF-80 SC), this uses the AW-1 oil, which I think is a synthetic oil.
Post Thanks / Like - 1 Thanks, 0 Likes
5th September 2018, 18:18
#5
Originally Posted by
Mike_B_C
I have the af33....
Sent from my SM-G965F using Tapatalk
5th September 2018, 19:53
#6
Found this. Which should just about be everything i need to stop me panicking..... erm i mean everything i need to get it done.....
https://vectra-c.com/forum/showthrea...40-gearbox-oil
6th September 2018, 07:08
#7
Life, just when you think your about to get a bj she turns out to be a homicidal maniac!
At least the knowledge is on here to stop to panicking.
7th September 2018, 09:46
#8
So it all got even worse today. Oil leak started and dumped 2 litres of oil on the ground during the test drive to check the gearbox after the ATF change. Then the gearbox dumped who knows how much oil out on the test drive when the newly fitted drive shaft SOMEHOW popped out of the gearbox slightly. I then spent the best part of 2 hours getting to the gearbox dipstick (no fun on the 3.0) to check the ATF level and the b@5t@rd snapped off in my hand. £50 for a new one....?!?!?
