4th September 2018, 06:44
#21
Originally Posted by
Steel
I have 17" rims, I'm guessing the reason the VXR is on 18's is due to the dbigger discs and fact that the caliper is spaced further away from the hub centre.
I saw a previous post where they were talking about police spec Vectra's having 345mm VXR brakes with 17" wheels and there was a picture, but it looked likely that the calipers would scrape wheel weights off.
Yup the police ones have 17”s you know the facelift elite alloys so they are fine behind that. I’m not sure about the 17” sri alloys though can’t remeber the details as it was so long ago I was upgrading brakes but I’ve always had 19”s so never had to worry.
The standard back plates are ok with 314 as I recall I think you have to trim a bit to clear the Caliper that’s about it.
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
Post Thanks / Like - 1 Thanks, 1 Likes
Steel thanked for this post
4th September 2018, 06:59
#22
Yep, just need to remove an inch or two from the dust guard, @plasma surgically removed mine in situ... Have a look at some of the older threads.
4th September 2018, 13:29
#23
Dog_Book
hmmm true that, saying that the farmer opposite the site i work on now he's got a massive one sounds like a gas turbine like an Abrams rolling past without the tracks
i'm told i've got a massive one......
also the 345's fit under pre-face sri 17 alloys
check my post from 10 years ago! https://www.vectra-c.com/forum/showt...741-314-vs-345
Post Thanks / Like - 1 Thanks, 2 Likes
4th September 2018, 13:39
#24
Will 314 fit under 16" alloys?
4th September 2018, 16:25
#25
Inovator
Yes they will mate
Sent from my iPhone using Tapatalk
Post Thanks / Like - 1 Thanks, 0 Likes
4th September 2018, 19:02
#26
I found that thread last night, excellent reading and if I had found it earlier I wouldn't have needed to post here, everything I needed to know is on there, great piece of work by the way.
test_uk
4th September 2018, 19:04
#27
Thanks Fred, is the mod to the backplate just round where the caliper mounts? Also do you know what plasma used to 'surgically' remove the excess tin?
fatfred
4th September 2018, 19:09
#28
Steel
Plasma cutter
I've used 4 1/2 angle grinder.
4th September 2018, 19:42
#29
.....groan
It was a battery grinder iirc. Just needed to remove a small section.
4th September 2018, 19:44
#30
Samyam
Yes they will mate
Be very very careful. They will fit under some 16s but not all by a long chalk. I fitted 17 elites on mine.
