Thanks Thanks:  2
Likes Likes:  1
Thread: vectra c estate alarm problems
    May 2014
    Cambridgeshire
    Vehicle : Vauxhall Vectra
    Engine : 1.9 Diesel
    Default vectra c estate alarm problems
    Hi,
    The siren on my alarm goes off randomly; even though the car is not locked or; or alarm on. it is sometimes is within minutes, and some times a week.
    The temperature or weather makes no difference.
    The only thing that I can think off is that the actual alarm back up battery is faulty, that's if it has one.
    Any advise would be helpful.
    I have read lots of threads of this problem, but they all with the alarm on.
    Rolyh
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    does it say safeguard on the dashboard
    May 2014
    Cambridgeshire
    Engine : 1.9 Diesel
    No, it doesn't, but I can make it come on by removing F21 and F23(alarm) fuses; disengage the alarm, but that would be expected.
    But I only do that at night so as to not annoy any one.
    The strange thing is that the car does not be locked or alarmed, but the alarm will still go off randomly..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 167340
  5. Thanks autov thanked for this post
    Likes soulman liked this post
  6. #5
    Berkshire
    29 Post(s)
    Vehicle : Toyota
    Trim : Yaris Hybrid
    Engine : 1.5 Hybrid
    Year : 2021
    Mileage : 5525
    hopefully the op will find their fault there ^^^^^^^^^^
  7. #6
    May 2014
    Cambridgeshire
    Engine : 1.9 Diesel
    Thanks, I have read the thread, and easily found the connections to the rear fixed windows. I shall link both with a bit of copper, then remove one at a time to see which one is the problem.
    But firstly I have cleaned the connectors and fitted them back in place, as from my experience a lot of intermittent electrical problems are poor contacts. It may be days before I know what clears the problem, as it can occur infrequently.
    But I will up date this thread when I know the answer. Rolyh
  8. #7
    Regular Member bigdov's Avatar
    Oct 2016
    Fife
    11 Post(s)
    Trim : Design V6
    Engine : z28net(l)
    if its coming on randomly i would put money on it being the batteries in the power sounder starting to fail, giving the age of the vectra's now its highly likely.
  9. #8
    Sep 2014
    uk
    Vehicle : vectra C sri estate auto+ hatchback auto x 2
    Trim : est sri auto hatch design auto x 2
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    Quote Originally Posted by bigdov View Post
    Just out of casual interest and just in case, where are they located.
  10. #9
    Administrator plasma's Avatar
    On the Forum
    574 Post(s)
    Engine : 150
    Mileage : 74000
    behind the fusebox in the rear left cubby hole of the boot
  11. Thanks autov thanked for this post
  12. #10
    13 Post(s)
    Just to add to Plasma's comments, the batteries themselves are inside the power sounder, which is where he's said it is located.
    But not sure if they're still available, or no obsolete?
    If you disconnect the power sounder, then chances are the alarm or car horn will sound, possibly both.
    To prevent this, first switch on and off the ignition, then disconnect the battery under the bonnet within 15 seconds. It pays to slacken off the batt terminal beforehand so you're not fighting time while using spanners.
  1. 2007 Vectra Estate ALARM
    By Tank988 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2014, 18:33
  2. vectra c estate 07 alarm sounder
    By sausaged in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 16:52
  3. Alarm Randomly going off???? - Vectra 2006 Estate
    By TheSnowMan in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2012, 14:13
  4. Vectra C Estate Life (2008) Alarm Issues
    By Shoty32 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 14:38
  5. Alarm problem-06 vectra estate
    By graeme900 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th July 2010, 09:31
vectra c siren alarm
