evening everyone,
finally got the exhaust issue on my z30dt fixed and dpf problems have disappeared but i now am left with a very annoying coolant leak issue, the car is using a small amount of coolant (maybe 500ml) but does not seem to use it at the same rate every time, i cant see any obvious leaks under the car and their is no major pressure build up in the cooling system.
no mayo on the oil cap either.
even when the coolant is low and the low coolant light is on the car never overheats. max temp never breaks around 100 degrees.
wondering if anyone knows of a site that shows the locations of all the various coolant hoses so i can try and check each one for pinholes or damage.
it is strange this problem only seems to of started at the same point as exhaust flexi became suddenly worse(i.e. louder and causing the repeated attempted regens) so im wondering if something came detached from somewhere and may of hit a hose or something.
i do notice a very small drip on the drivers side bulkhead but im not certain if that could just be the air con drain.
