Results 1 to 5 of 5
Thread: Z30DT spanner warning light
    Feb 2013
    Magyarország
    Vehicle : Opel Vectra
    Trim : C Caravan
    Engine : Z30DT
    Year : 2008
    Default Z30DT spanner warning light
    Hi all,
    I need some advice:
    After turning the key to ignition, the spanner warning light flashes 5 times (only this flashes, not more). What does it mean?
    Based on the manual this light could mean two things:
    1. On ignititon, it illuminates - that means that the preheating system is active.
    2. During the engine is running, when it flashes continuously - that means that the automatic dpf cleaning cannot operate automatically.
    But what does that mean when it flashes 5 times on ignition and during the engine’s running there’s nothing?
    Infos:
    - Based on opcom data, the dpf is on 200% fulfillment.
    - Last weekend I went a long trip with 85 mph for 2 hours (Z30DT Automatic in 6th gear), but the automatic cleaning didn’t start.
    - There’s no hole in hose pipe.
    - There’s no error codes, checked by opcom.
    thanks,
    Jun 2015
    Riga
    8 Post(s)
    Trim : Elite custom
    Engine : 3.0
    Mileage : 95kMiles
    It is too filled to regen.
    Feb 2013
    Magyarország
    Trim : C Caravan
    Engine : Z30DT
    Year : 2008
    Quote Originally Posted by JunckMAn View Post
    What can I do?
    Apr 2008
    West Yorkshire
    Force a regeneration via opcom (if you can! ) then take it for a good drive in a low gear and high revs etc.
    Feb 2013
    Magyarország
    Trim : C Caravan
    Engine : Z30DT
    Year : 2008
    Quote Originally Posted by NickT View Post
    Thanks, opcom cannot do regeneration in Z30DT, so I will take a ride.
  1. car with spanner warning light 2.0 DTI
    By Kyle in forum Engine & Drivetrain
    Last Post: 16th October 2015, 17:50
  2. Replies: 0
    Last Post: 26th February 2015, 12:38
  3. Replies: 6
    Last Post: 17th November 2014, 21:56
  4. Z30DT - Engine Light Illuminated, Car with the spanner through it?
    By Ben Chiles in forum Y & Z30DT Specific
    Last Post: 14th May 2012, 06:31
  5. Spanner warning light
    By olearysp in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:41
