Thread: No throttle response
    Jan 2018
    Paisley
    Vehicle : Vauxhall
    Trim : Vectra C
    Engine : 1.9 CDTI
    Default No throttle response
    Good evening gents and any laides present,
    Newbie to the site and looking for any available assistance for a problem with my 2006 1.9cdti 8v vectra C, a problem which has lamost got me defeated.
    Having issues with no throttle response and self revving at around 13k revs, I changed the throttle body few months ago, however, the problem has re-occured. RAC read the following fault codes:
    P0340, Camshaft position sensor
    P0641, 5V reference circuit 1
    P1125, Throttle Actuator feedback circuit
    P0638, Electronic throttle control
    P0105, Boost pressure sensor
    P0110, IAT
    I have seen this issue is very common on forums, but never really find anyone getting to the bottom of it? Hoping someone may have solved this and can shed some light on it, also hoping someone could pass on or inform myself where I can locate the wiring diagrams for this motor so I can check earth points, confirm if the above sensors are all on the one circuit and maybe help me trace this 5v reference circuit problem.
    Any advice or diagrams will be greatfully appreciated.
    Scott
    P.S I have checked the resistance in the above sensors and seem ok, physicaly checked the wiring and no sign off damage, I have also had the ECU tested at BBA and there is no fualt with this apparantley.
    Apr 2008
    West Yorkshire
    I would look at the circuit diagram and see if the 5v reference feeds all of the sensors first. If they do then I'd remove all of those sensors, measure the 5v signal and then plug on each sensor one by one until the 5v voltage level drops. I'd remove that sensor and then add the others to check that the 5v level remains. You've then narrowed that down to the sensor that is causing a partial short causing the 5v voltage drop that would in turn give the fault code errors on all of the sensors.
    Testing the ecu on its own on the bench the ecu testing place would check for the 5v level but not necessarily under load with the sensors in place.
    I would hazard a guess that it would possibly be the:
    "P1125, Throttle Actuator feedback circuit"
    as this is a typical voltage potentiometer circuit that is a 'wiper' over a resistor and is a physical wearable item. Note I'm not saying this is the actual fault, as I haven't diagnosed your car or seen it.
    Good luck with it.
    Regular Member rmsNoel's Avatar
    May 2014
    in my garage
    Vehicle : vectra Cdti
    Trim : design+
    Engine : cdti 120
    Mileage : 51,321
    Is this like the one where the solder comes away from the board on throttle body and causes all sorts of chaos
    Jan 2018
    Paisley
    Vehicle : Vauxhall
    Trim : Vectra C
    Engine : 1.9 CDTI
    Quote Originally Posted by NickT View Post
    Good luck with it.
    Hey Nic thanks for the reply, should have the ECU back today and will carry out the above checks, only drama I am facing, and hoping someone on here could assist with, is getting a hold of the schematics. I have hunted the web to no luck, Haynes doesnt show the power distribution that I require.
    I was reading last night of a fella with an astra and had similiar symptoms, there was a mention that the pedal wiring went from acc pedal to ECU via UEC, which is prone to water ingress, corrosion etc, and can cause a continuity problem, I had the UEC off the other day, however, it looked ok, but I didnt clean it so will try that too.
    If it is was to be the 'Throttle Actuator feedback circuit' I will be pretty P'd off as I have changed the throttle body for a brand new part.
    Jan 2018
    Paisley
    Vehicle : Vauxhall
    Trim : Vectra C
    Engine : 1.9 CDTI
    Quote Originally Posted by rmsNoel View Post
    Hey rmsNoel, Ye apparantley that can be a fix, but wasnt in my case. I went as far as removing the old solder joints completley and putting new
    on, but the porblem was still there so replaced the unit, which I thought had done the trick until it re-appeared a couple weeks ago.
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Quote Originally Posted by scottyw83 View Post
    The TB does not control engine speed so could be leading you down the wrong path, this might be a worn track on the throttle pedal. Could try getting a used one and replacing it see if it works?
    I don’t even know why the TB has so much electronics in it all it does is close on shutdown then open back up
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
  1. Bad throttle response
    By Hodgy in forum Engine & Drivetrain
    Last Post: 6th February 2013, 19:21
  2. No throttle response Cdti 120
    By Vectra Meldrew in forum Engine & Drivetrain
    Last Post: 1st August 2012, 13:05
  3. Bad EGR and no response from the throttle 2,0 DTI
    By ldanieli in forum Engine & Drivetrain
    Last Post: 13th February 2012, 19:38
  4. Throttle response
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2009, 08:27
  5. No Throttle Response When Cold
    By VectraV6CDTi in forum Engine & Drivetrain
    Last Post: 11th January 2007, 18:29
