Thread: oil leak
    dumbarton
    Default oil leak
    just wondering if any one has had i leaking inter cooler i found oil around the front bumper and when i investigated it semms to be coming from the inter cooler also wonderer is it was covered under warenty cheers folks
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    If it's oil coming from the intercooler then the seals in the turbo are on the way out....should be covered under the 3yr warrenty
    Regular Member stickshift's Avatar
    North London
    If it is the seals you will need to be careful as the oil could get into the inlet manifold causing the engine to race as it will run on engine oil just a well as diesel and you won’t be able to control it. If it does happen put it in gear and stall it. It might seem an extreme scenario but I’ve seen it happen usually accompanied with a cloud of white smoke from the exhaust
    and if it does start running on it's own oil it will race away and destroy the engine..
    the intercooler will not have any oil in it..as said before, if there's oil in it, then the turbo is dead
    dumbarton
    hi thanks for your reply i noticed the oil when the car was in for a service it is definetly coming from the intercooler it looks damaged you heve got me worried about the turbo now cos the car drives normal its done 80.000
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. Oil Leak
    By Tam80 in forum Engine & Drivetrain
    Last Post: 17th January 2011, 13:41
  3. Oil leak
    By Rich2.2 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 20:31
  4. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
  5. 3.2 oil leak from?
    By megaderek in forum Engine & Drivetrain
    Last Post: 29th September 2009, 22:45
vauxhall vectra cdti leaking intercooler www.vectra-c.com
