Thread: Spanner came on while driving, no boost
    Jun 2018
    Engine : 2.2dti Auto
    Mileage : 200021
    Default Spanner came on while driving, no boost
    The spanner on my vec came on whilst driving to work this morning and was flat through all the gears, as if a boost pipe had come off. No eml and I parked up and found no boost leaks. Left it 5 mins and it went back to normal when I turned it back on. Any idea what this could be? Also, the top hose in the picture was cool after a 25 mile drive, is that normal? (The one just on the right of the ecotec badge)
    Sent from my SM-G935F using Tapatalk
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    30 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    that top pipe is a boostpipe so yeah it should be cool.... you need to take of the cover and check those little white plastic pipes as they are the vacuum pipes and if they have a break or split or the connectors have a split your car will go into limp mode (the no boost thing you experienced) by turning the car off and back on the ECU will clear this mode and the car will respond normally again...
    that said with the car acting normally after you turned it off... check the big boostpipes for splits or leaks i can clearly see you have the oem rubber pipes and these can leak/split after a few years of service.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    Hello this might help you with the vacuum hoses (another members pics) also the boost sensor may need cleaning i do have a pic to help but cant upload photobucket pics to here anymore.
    https://www.vectra-c.com/forum/showt...ghlight=2.2dti
    Jun 2018
    Mileage : 200021
    Thanks. The car has just clocked over 200k and I said if it made it that far without breaking i'd spend a bit on it (I paid £400 for it at 193k). This weekend I will be changing:
    - discs and pads front/rear + pad sensor
    - sachs shocks front and rear + eibach springs all round. The old shocks are f****d and springs haven't been changed as pairs so sitting at a weird angle.
    - front drop links
    - boost sensor and egr clean + inlet manifold gaskets
    - thermostat change + coolant temp sensor change
    - oil+filter/air/pollen filter change.
    I'll check all the clips and boost pipes for any small leaks
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you checked for any stored/active codes?..I would want it diagnosed and running right before spending anything on it...BUT thats me
    Regular Member CLUB04's Avatar
    Jan 2014
    Watford
    Trim : SRI
    Engine : 2.2 Direct
    Mileage : 84,000
    Most likely to be a boost sensor in my opinion, had the same on mine.
    Sent from my F8331 using Tapatalk
  1. Z20NET, No Boost, Cuts out whilst driving :(
    By rad9944 in forum Engine & Drivetrain
    Last Post: 12th April 2014, 14:06
  2. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  3. Spanner Light on for the first minute of driving.....
    By focus_driver in forum Engine & Drivetrain
    Last Post: 20th November 2009, 19:44
  4. spanner light whilst driving
    By porthy-t in forum Engine & Drivetrain
    Last Post: 8th November 2009, 17:27
  5. Yellow spanner light when driving....
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 08:18
