Vinyl - https://www.mdpsupplies.co.uk/vehiclewrapping.asp
Slight update on the Vectra... I had a quick read of previous posts i made in here and noticed I had mentioned the Gearbox sounding a little worse for wear. That proved to be true and it gave up the ghost in October. I was a little stuck as this is usually something id do myself but im working away from home at the minute and i needed it doing in a day so i had to fork out for a 2nd hand box & the labour. I've got my original M32 box and may or may not refurb it at a later date but either way im not expecting much more than another 6 months form this box so it may be a case of going to F40.
Apart from that ive had no issues with the car really, the fan relay gave up and i realised my passenger footwell was soaked over christmas so i sorted the drain holes out in the bay & I've just received a new relay. A new cruise control stalk sorted the issues I previously mentioned too.
I've covered 12,000 miles since i got the car and its been good so far i quite like it, its at 95,300 as we speak.
So since last time ive changed the following:
Gearbox & Gearbox Oil
De-wiper rear (glass bung)
Front Aero Wipers
CD70 Navi Unit
Color Coded Rear Boot Strip
De-badged the Rear
New Cruise Control Stalk
Tinted Reverse Section of Rear Lights
Tinted Centre Brake Light
Black Wrapped Window Chromes
Full Service:
Oil
Oil Filter
Pollen Filter
Oil Flush
Fuel Filter
Air Filter
Fuel Treatment
3 by T.walker5190, on Flickr
DSC09170 by T.walker5190, on Flickr
DSC09175 by T.walker5190, on Flickr
DSC09171 by T.walker5190, on Flickr
DSC09176 by T.walker5190, on Flickr
I think the rear end looks too blank with all of the badges gone, so i've bought this which needs a little tidy its from an old Vauxhall Viva which im going to stick on once ive done a final polish of the rear & waxed the new paint in a few weeks.
I've got an MOT in Febuary and I've ordered a load of LEDs to slowly do an interior color change of the clocks etc. Foolishly i thought all CD70 where bluetooth & aux input so im probably going to upgrade that at some point. Should have a few other little things done around March time so will update then.
Tidy looking car that...
If it helps, I had similar symptoms of the cruise control switching off and out was due to dirty contacts at the indicator stalk. I removed the stalk using an unwound paper clip slotted in the back to remove the stalk, then used proper elective switch cleaner to clean the operating contacts where the cruise control fits into.
the car looks lovely mate and very well looked after
but i personally think that fitting a badge from a Viva HA from the mid 60's would waste the look.
but...its your car and at the end of the day, thats all that matters.
Little update on the Vectra. Passed its MOT without anything other than 2 advisories on tyres which I was pleased with, I was quite lucky with this as I'd felt the rear passenger side caliper binding a little just after the last update so I'd changed that a few weeks prior to the test. I switched out the Heater Fan relay which resolved that issue too. I decided to try and find some wheels & tyres rather than just put a fresh set of tyres on them wheels, the fronts where flagged in MOT but the rears werent that great either.
Also I decided it was time to give it some TLC as its done me well since i got it and I'd like to keep hold of it for a decent while. So I gave the archs the once over and ordered a few bits of cleaning kit that i need replenished.
So since last time I've done the following:
MOT
Rear ARB links
Rear N/S Caliper
Brake Fluid renewal
Heater Fan Relay
Anthracite XP2 wheels
4x New Tyres
Wheel Archs Cleaned
Items Painted:- Calipers & Carriers (Red), Track Rod Ends, Rear Suspension Arms, Shocks, Front Droplinks, Front & Rear Brake lines (Black)
Gave it a quick once over clean as the weather isnt holding out for me to do anything decent but the paint works full of tar and swirls so next step is to hit it with the DA and get some decent coats of wax on there. Will update with a mini-detail soon. Some pictures:
Archs before & afters:
2 by T.walker5190, on Flickr
4 by T.walker5190, on Flickr
The car:
DSC09179-2 by T.walker5190, on Flickr
DSC09187-1 by T.walker5190, on Flickr
DSC09194-4 by T.walker5190, on Flickr
DSC09183-3 by T.walker5190, on Flickr
DSC09196-5 by T.walker5190, on Flickr
The rear bushes dont look so great, most of them look tired so I'm going to slowly switch them all out for powerflex units starting with the bottom rear arms (Spring mounts) & the ARB bushes so in terms of parts that stuff will come next.
Other than that the cars not low enough so when the shocks eventually give in i'll be throwing some coilovers on it.
Looks amazing, but can't help think the tyre profile is to small?
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
