Hi i have signum 1.9cdti 120bhp. When i accelerate slowly car starts jerking from 1800-2500rpm. But when you push hard nothing, no faults on diagnostic. Second problem when car heats up to 90degrees the gear stick get stiff.. Any help??? THANKS
Check the oil level in the gearbox.
Ok will have lool thanks
I have this problem with the judder but no gearbox problem!!! Any ideas chaps? Egr valve?
throttle body,the butterfly flap may need cleaning or the internal part covered in oil
have a look in the how to section or look on u tube
give the egr a clean
Found it in a past thread thanks pal one garage I asked recommended running some forte cleaner through?
Teapot Tuned 255/300
Tech2 & MDI diagnostics + SPS
