Likes Likes:  1
Thread: Exhaust bore size
    Jan 2015
    derby
    Vehicle : vectra c sri
    Trim : sri xp
    Engine : 1.9
    Default Exhaust bore size
    Hi chaps own 1.9cdti been offered twin exit exhaust but it's from a 1.8 petrol is bore size an issue. Wont be having front pipe or middle box.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    34 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    yes the 1.8 has a slightly smaller size so you'll need an adaptor to step down from your front pipe to the middle pipe... other than that it should all be a direct fit... not to sure about the adverse affects it might have on the gasflow but don't think it'll be a problem as it is to far down the exhaust line anyway..
    Apr 2008
    West Yorkshire
    Any decrease in bore size will cause a showdown of the overall laminar flow and exhaust scavenging etc.
    Apr 2016
    Ipswich
    34 Post(s)
    Mileage : 140000
    Think you forgot some of the aspects of a dual exhaust VS single exhaust
    the gasses will flow out regardless of the tiny reduction.. as the narrow bit is to far down the line... also he'll endup with double the amount of exit points plus double the size of pipes... it would be different if he already had a dual exit exhaust and would than go to a smaller diameter... overall he's actually extending the exhaust diameter by as much as 1.4 times (and i'm confident it's more) and actually reduces the resistance (from the smaller diameter) by adding the extra back box...
    so no it shouldn't be a problem like i said before...
    Full Member Darklord's Avatar
    Apr 2018
    Northeast
    Vehicle : Vauxhall Vectra
    Trim : LS/Life
    Engine : 1.8
    Just make sure it's not made by Klarus!
    My new exhaust clearly has little internal baffling compared to the original, and the rear box blares, guffaws and belches rudely at times, in fact it reminds me of an old Morris Minor, with its belching exhaust note upon gear changes.
    The system is accurately made and fitted well. But it sounds incongruous at times.
    Well I suppose it was cheap...
    Apr 2008
    West Yorkshire
    Quote Originally Posted by northpole View Post
    Without a pipe layout I wouldn't be able to do the dynamic fluid analysis and losses calculation.
    Good luck with the replacement, I hope it works out.
  7. Likes northpole liked this post
  8. #7
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 74000
    1.8 never came with a twin exhaust so it will be from another Vec anyway, unless it is a custom built exhaust. 1.8 had an internal dia of 41mm, but if its cheap enough just get a stepped reducer cheaply off ebay.
  9. #8
    Jan 2015
    derby
    Trim : sri xp
    Engine : 1.9
    Thanks for all your advice chaps ��
  1. SRI Exhaust Back Box Bore Size
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 18th June 2012, 15:20
  2. Exhaust bore size on 1.9 150bhp?? Help
    By simmo3187 in forum Diesel Engine related
    Last Post: 7th December 2011, 23:00
  3. exhaust bore size
    By craig1989 in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2010, 09:27
  4. Exhaust bore size 2.2dti/1.9cdti
    By John LE in forum Diesel Engine related
    Last Post: 4th May 2010, 19:19
  5. VXR Exhaust Bore Size...
    By damian s in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2010, 18:40
