Thanks Thanks:  1
Likes Likes:  2
Thread: Removing a crankshaft pulley bolt
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Default Removing a crankshaft pulley bolt
    I'm after some advice with removing a crankshaft pulley and seal.
    Friend has a 207 1.4 petrol.
    I've located the oil leak and it's dropping from the crankshaft seal.
    I don't have a impact wrench, but wondered if it was possible to use a braker bar to get the bolt off. Or if there was a way you have to remove them.
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    34 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it should come off if you use a breaker bar with a long extension on it so you can apply more force, granted you've got space to use the extension and have locked the flywheel so the crankshaft doesn't move.... sticking it in gear might help but if it has never come off before it usually means you'll have to use locking tools.
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Can overfilling the oil cause crankshaft seals to leak? I'm having a debate with a person. He's saying no.
    Basically his brother balled up and put 5litres of engine oil in a car that's suppose to only have 2.5-2.75 lites. The car was driven about 4 miles until he realised. He drained the oil and tbh it looked like more than 5litres were in the system .
    Now he has a oil leak. I've taken a look at it and cleaned it all with brake cleaner and you can start to see it leaking from the front crankshaft pulley. (Drives the aux belt) so I suspect it's the seal. But without taking the pulley off we can't confirm it.
    To to clear the argument up. Can to much oil blow crankshaft seals. I've said yes.
    Apr 2016
    Ipswich
    34 Post(s)
    Mileage : 140000
    you are right the system get's pressurised by the oilpump while driving... to much oil will add to much pressure and because it can't go anywhere the seals can pop... usually on the crankshaft and behind the flywheel... but i have seen it come out of other places like the sparkplugs, rocker covers, and even cause so much damage that it broke the headgasket... (30 years of working on cars makes you see loads of weird and wonderful things)
    so yes you are right...
  5. Thanks chris1804 thanked for this post
    Likes chris1804 liked this post
  6. #5
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Quote Originally Posted by northpole View Post
    Mate, I've never seen anything like it. Last week when he told me what his brother done I was shocked. Because it was only 2 days before he done this he had the head gasket done.
    I said get new spark plugs and a new air filter and I'll change them. The plugs wasn't that bad tbh there were dry surprisingly. But the airfilter, my god it was swimming in oil. All the breathers were caked in oil and needed cleaning
    Head gasket seems to be fine luckily but time.will tell.
    Thanks for settling that argument,
  7. Likes northpole liked this post
  1. Crankshaft pulley
    By Chaz1969 in forum Engine & Drivetrain
    Last Post: 26th March 2016, 16:07
  2. URGENT - Crankshaft pulley bolt
    By davedrinks in forum Petrol Engine related
    Last Post: 13th November 2014, 08:44
  3. crankshaft pulley
    By djsoundman in forum Engine & Drivetrain
    Last Post: 20th November 2009, 12:05
  4. Yet Another Crankshaft Pulley!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2008, 00:27
  5. Need Help with Crankshaft Pulley Bolt!!
    By Paul from Derby in forum Engine & Drivetrain
    Last Post: 29th April 2007, 08:15
