Results 1 to 10 of 16
Thread: Z30DT Swirl Flap error P1112-62
    Aug 2007
    Essex
    Engine : Z30DT
    Year : 08
    Default Z30DT Swirl Flap error P1112-62
    Hi all
    As per title I have an error code of P1112-62 (swirl flap stuck open bank 2).
    From reading I can see many have bypassed these on a 1.9 but I can’t see many that have done these on a Z30DT.
    i saw this
    https://www.vectra-c.com/forum/showt...-Engine-lights
    but I was under the impression that these engines couldn’t be touched regarding the ecu remapping, has anyone had any experience with having these engines remapped as I would live to have the dpf regen removed as well as the swirl flaps deleted.
    Anyway like the 1.9 is there a master control swirl flap that has to be working on these engines so I can glue the others open?
    Has anyone removed their inlet manifolds to clean it? Was it an awkward job to do?
    Posdibly further questions to come as I might try and take them off and clean them on Saturday if nothing els can be done.
    cheers
    GSMB
    Aug 2007
    Essex
    Engine : Z30DT
    Year : 08
    A quicky question, is bank 2 to the front or rear inlet manifold?
    Aug 2007
    Essex
    Engine : Z30DT
    Year : 08
    Ok so I managed to change my scv instead of the swirl flaps, but I now know that it’s the actuator not working but on bank 2 (bank 2 being that the front I now know) and I did clean all the inlet manifolds up do should be better now.
    I might see if I can find someone to map it out and should be fine with it as they are sprung open and vac closed so no need to glue it open.
    Apr 2008
    West Yorkshire
    If I remember right the swirl flaps are controlled by vacuum but position feedback is by the potentiometer at the end. Check for electrical connection at the sensor point and/ or use a vac source on the vac pipe to see if it will open. I had a split diaphragm on swirl valve actuator on my old 1.7 izuzu diesel that caused a fault so finished up replacing it and it ran great afterwards.
    Well done on the scv replacement
    Good luck with it. I do love my V6 z30dt
    Aug 2007
    Essex
    Engine : Z30DT
    Year : 08
    Cheers mate, I couldn’t see any connections for a potentiometer only a connection for the actuator, which your right it is vacuum controlled unit. I did rev the engine and I didn’t see it move so I swims it’s knackered, but rather than messing about with it I might see if I can get it mapped out.
    Apr 2008
    West Yorkshire
    If it's the bank to the front of the car, the potentiometer bit is near the egr left side of the engine near the oil filler under the plastic engine cover. Look for a black circular part underneath the egr electrical connector.
    It's just underneath the arrow end on Google image:
    https://www.google.co.uk/search?clie...6zuT87q-vxU9M:
    Apr 2008
    West Yorkshire
    Did you clean the manifold itself and see if the swirl valves moved? I just cleaned mine add a mayer of course when I did the scv on my engine
    Aug 2007
    Essex
    Engine : Z30DT
    Year : 08
    Both sets of swirl flaps worked fine, but I did give them a clean.
    The black circular thing I though was just the actuator.
    How much should it move via the throttle?
    Apr 2008
    West Yorkshire
    It operates by the ecu operating the vac solenoid (blue and black I think), which is not just dependant on throttle. There should be a T or Y piece where the vacuum
    You could try using a vac source to see if you've just got a split pipe or check the electrical connector on it
    Aug 2007
    Essex
    Engine : Z30DT
    Year : 08
    Oh ok I get what you mean, not sure what vac source I could use though
  1. Swirl flap removal 3.0cdti z30dt engine
    By 3.0 CDTI newbie in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2016, 06:34
  2. P1112 swirl valve
    By steve1975l in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:56
  3. error code p112-61 swirl flap stuck
    By dahmich in forum Engine & Drivetrain
    Last Post: 7th December 2012, 13:36
  4. Hi CO and Swirl flap code P1112
    By silflex9 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 11:44
  5. P1112 Swirl flaps
    By patc in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 22:23
z30dt fault code p1112-62
błąd p1112 z30dt
