Results 1 to 3 of 3
Thread: Swapping front drivers door
    Jul 2014
    Coulsdon, Surrey
    Vehicle : VECTRA SRI NAV T Estate
    Engine : Z20NET
    Default Swapping front drivers door
    Had a replacement drivers door delivered this AM. Mine got dented in a minor RTA a while back, the culprit's insurance never contacted me and I decided not to pursue a claim (right or wrong).
    Anyhow, the door arrived with the lock tab in what appears to be the 'up' position but it won't push down. Door card isn't fitted so it might be locked; it's hard to tell!
    I've done some research before posting this so I know I need to swap the door module from my original door but I'm a bit concerned that if I fit the new door and close it then I won't be able to reopen it!
    I need to swap the handle and lock cylinder from my original door. Would it be wise to also swap the closing/locking mechanism/catch as well? Is that a difficult operation?
    Jan 2008
    110 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    I would swap everything except for the electric window mechanism.....that way you know it's all yours
    As for the lock tab???
    I assume you mean door pin on top of the door that goes up and down when locking/unlocking???
    If so, then you usually find that when the door is open, the pin doesn't go down anyway, so it's probably in the correct position.
    South Central - Assistant RO Matty2Fatty's Avatar
    Mar 2014
    West London
    88 Post(s)
    Trim : Elite Estate
    Engine : 1.9 CDTi 16v 120 BHP
    I can also recommend to not shut (and lock) the door with no exterior handle on, makes it pretty difficult to open as it jams
    Click HERE to see up and coming events
  1. Door Locking Mechanism-Drivers Side Front
    Last Post: 28th April 2009, 12:17
  2. Drivers Side Front Door Glass
    Last Post: 28th April 2009, 09:50
  3. Drivers Side Front Door Card-SRI
    Last Post: 18th February 2009, 13:42
  4. Door Glass for SRI-Drivers Side Front & Rear
    Last Post: 20th November 2008, 11:34
