Results 1 to 9 of 9
Thread: Today is....
    Full Member Darklord's Avatar
    Apr 2018
    Northeast
    Vehicle : Vauxhall Vectra
    Trim : LS/Life
    Engine : 1.8
    Default Today is....
    MOT day!
    How long will the failure list be I wonder...
    Soon find out...
    VIP-Member Rhodie's Avatar
    Oct 2014
    Ossett, W Yorkshire
    23 Post(s)
    Blog Entries
    1
    Engine : 1.9 CDTI 150
    Mileage : 75000
    Good Luck
    or
    2007 1.9 CDTI Elite hatch 150. 2 x led boot lights, HID's, aux, comfort unit, circular wheels, overhead roof and see through windscreen
    Jul 2014
    Coulsdon, Surrey
    Vehicle : Vectra SRi T estate
    Engine : 2.0 Turbo
    Year : 2008
    I usually worry a little but the car sails through with nothing of concern!
    Hope the same applies to you
    Apr 2018
    Northeast
    Trim : LS/Life
    Engine : 1.8
    Well, the result was...
    1. A corroded brake pipe
    2. Oxygen sensor
    3. Fuel leak
    I'm awaiting a call tomorrow for the cost estimate. But overall, the garage said it was a good solid car.
    I'm quite pleased with it considering how little I paid for it - let's hope the bill is small!
    Apr 2018
    Northeast
    Trim : LS/Life
    Engine : 1.8
    Ok, well this has turned out puzzling.
    The garage phoned to say that they had ordered from the dealer and fitted a new fuel pipe and fittings - fuel leak repaired. So far so good.
    The other failure point was that the EML was on, and I told him I thought an oxygen sensor was faulty. However he said he read the codes, and monitored the live data, and discovered that both sensors were working, and the light stayed off on a test drive, so he will now pass it.
    Question is, I know fine well it will be back on again soon! Any ideas what is causing it?
    Apr 2008
    West Yorkshire
    Post fault codes found to give a starting point
    Apr 2018
    Northeast
    Trim : LS/Life
    Engine : 1.8
    Quote Originally Posted by NickT View Post
    It's always the same code - P0141.
    Jun 2018
    Oxfordshire
    Engine : 2.2dti Auto
    Quote Originally Posted by Darklord View Post
    Bank 1 sensor 2. That's post-cat. If it comes on after a long drive and the sensor is still reading correctly then i'd assume that could be pointing to a failing catalytic converter.
    I would still change the O2 sensor first though, given it's the cheaper option.
    Apr 2018
    Northeast
    Trim : LS/Life
    Engine : 1.8
    Many thanks, I might try some Cataclean...
  1. Well today had the VXR wheels refurbed today
    By Angel1368 in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2018, 20:08
  2. mot today
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2014, 19:38
  3. What you all been up to today?
    By Cam in forum General Chat
    Last Post: 20th December 2009, 08:50
  4. MOT today and it...............................
    By merikiito in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 09:33
  5. spotted this today in milton keynes today.
    By kev bux in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 09:00
