- Manuals
- Car Pass
- 1 Key (I only got 1 with it and never bought a spare)
- Service History (Below)
Notes
- I bought this in December 2016 and bought it with no service history. All service history I have is since I have owned it.
- The DESIGN on the drivers door is not for the trim level. The window mechanism broke, so I replaced the whole door.
Passenger side doesn't have a trim label on, so maybe worth removing it.
Pictures
All now attached, with names. Had to retake them all this evening as my first post didn't pass quality control.
Although, I have just noticed 3 (bad points listed below) I didn't re-take. I'll add them into the second post.
- CD30 (Currently not fitted). Will sell with current stereo intact, which has bluetooth etc, but this can be taken too.
- Coil Pack **
- Mass Air Flow Sensor **
- 4 original steel wheels. They are all bordering on illegal tread depth, so they would need new tyres fitting. (Think the 5th is in the boot - forgot to check)
** = I mis-diagnosed a problem, so replaced these, but turned out to be a blocked rocker cover, so while new ones are fitted, the old ones were not actually broken.
Bad Points
The main 4, in my opinion are;
1. The Drivers door has a mark on the edge, which was present (but I didn't notice until affter changing), when I bought it. https://www.mrmarlow.co.uk/vectra/15.JPG
2. The rear drivers side door has this mark, which was there when I bought the car - I did plan to replace, but never got around to it. https://www.mrmarlow.co.uk/vectra/16.JPG
