Results 1 to 10 of 19
Thread: What type of Glue?
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Default What type of Glue?
    What type of glue would I need to use to safely secure an irmy handbrake cover.
    Recently purchased cover off a forum member - great cover - but the glue is off and need to get some more!
    Any ideas!!
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    No more nails. It can even glue chairs to walls!
    Jul 2006
    Mexico
    You could try some epoxy kind of thing, you know the one that comes in separate containers and you mix equal parts of them.
    Feb 2007
    The pool
    the original one is from irmscher and all in German......
    I can make out that it has some kind of flexible properties.
    The likes of the 2 parters tend to set rock hard and would over time go brittle!?!?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    you should be able to get some from the dealers m8 as it is irmscher stuff
    Midlands Mod Shop - NFFC.
    Jul 2006
    Mexico
    Quote Originally Posted by Neil View Post
    Guess you are right, Epoxy might be too rigid. Maybe something like silicone will be better for this app.
    Feb 2007
    The pool
    Quote Originally Posted by BlueRob View Post
    I was thinking of using some trim tape - the stuff that the badges are held on with - but then thought as soon as contact is made that's it. If I ever needed to get it off there would be no chance.... Would have the flex required though!!
    Regular Member stickshift's Avatar
    North London
    What about the stuff the windscreen fitters use? It’s more of a mastic and stronger than silicone which would probably twist off!
    Does it glue on, ffs sounds a bit rough ? while we are on about them, does the button get replaced, or does the chrome one stay ??
    Feb 2007
    The pool
    chome one stays - the end result isn't that bad - will stick a piccie up in a few mins!
  1. super Glue
    By dazmufc in forum Bodywork & Interior
    Last Post: 8th November 2011, 23:23
  2. No solder- glue?
    By Reevo in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2010, 21:21
  3. Type of glue? Help
    By shan in forum General Chat
    Last Post: 12th December 2007, 20:39
  4. Super Glue??
    By C19_CJB in forum Styling
    Last Post: 14th October 2005, 14:33
