Thread: Broken window switch - Zafira B
    Oct 2015
    Krakow
    Vehicle : Zafira
    Trim : Cosmo
    Engine : z19dt
    Default Broken window switch - Zafira B
    Is it repairable or I need to replace the whole switch panel?
    Jan 2008
    110 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    If you strip the switch, remove the circuit board, then the silicon myler, you will see if the plastic contact is broken or not.
    If so, it'll be easier to change the full switch.
    Oct 2015
    Krakow
    Vehicle : Zafira
    Trim : Cosmo
    Engine : z19dt
    Ok, I've repaired the window switch
    12 Post(s)
    All I see is a black screen where presumably the photo should be.
    Maybe my employer is blocking it as they consider it to be a naughty hosting site?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    34 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it's on youtube you should be able to see it.... unless your employer has it blocked.. than you'll need to use your smartphones data connection to view the video...
    that all said... just take out the switch and open it up... there's almost nothing there that you can break so it is a safe and easy way of checking the state of it but knowing vauxhall 9 out of 10 times it is dirty, and a quick cleanup sorts the problem out
    12 Post(s)
    Quote Originally Posted by northpole View Post
    Nope, youtube is one of the few streaming sites we can still access. I'll try again later at home.
    Never previously had a problem viewing any of Kaliope's videos.
  1. No reverse light. Switch wires broken off.
    By Bertasius in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2014, 17:18
  2. Broken front electric window regulator
    By alanatrr in forum Bodywork & Interior
    Last Post: 14th April 2013, 11:22
  3. broken window wipers stalk
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2011, 15:56
  4. broken electric window??
    By BiggDaddyT in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2010, 18:00
  5. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
