Likes Likes:  3
Thread: Possible Engine Damage?
    Regular Member Sparky67's Avatar
    West Mids
    Default Possible Engine Damage?
    After having a petrol hire car for some time I unfortunately put petrol in my 63-plate Insignia CDTi tank on Saturday. Fortunately I caught myself, and filled the tank to the brim with diesel. The mix was about 35P:65D. I then carefully drove about 10 miles to where I had to be, the engine seemed fine, and later in the day drained the tank completely through the filter housing and refilled with diesel. It drove 30 miles home OK where I changed the fuel filter. It has started and driven fine this week so far, I can't feel any difference, with no sign of smoke in the exhaust. I've got 1000 miles ahead of me in the next couple of weeks. Have I got away with it? What could be the longer-term damage?
    13 Post(s)
    Quote Originally Posted by Sparky67 View Post
    Possible fuel pump damage more than anything else I would have thought due to reduced lubrication properties of having diluted the diesel with petrol.
    The engine itself will still be lubricated by the engine oil.
    http://www.autoexpress.co.uk/car-new...n-a-diesel-car
    West Mids
    Thanks for the link Dave. Just been looking at eBay for pumps - is there one in the tank and one on the engine?
    Midlands - Vxr Owning Dick Dog_Book's Avatar
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Yup, with what you have said and the fact it running quite happily I’d say you’ve been lucky and it’s all ok.
    If something had been damaged I’m sure you’d hear it by now
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    93 Post(s)
    Vehicle : Vectra C Saloon( sadly died at age 20 due to a hart attack)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    it won't cause any damage... it actually cleaned out the engine and the fuel system... you did what you needed to and that is change the fuel filter and replaced the mixture with proper diesel... problem sorted you just have very clean injectors/fuel pump/lift pump and super clean pistons/valves and ports... the biggest damage might be in the DPF.. but if the engine runs fine it'll be fine also
    this happened to me also and this was with an audi quatro 2.7 tdi (tuned to 350bhp) and i didn't caught myself i was driving and the engine started to act up... called the AA and they came emptied my tank and gave 20 liters of diesel... restarted the car and it ran better than it ever did before... when i got home I took the glowplugs out...and put a scope down it... the engine was clean... like a petrol car... went and checked the fuel filter.. it was extra dirty so replaced that the day after.. the car never ran so much smoother and idled a bit lower than before the incident...
    basically you gave the engine and fuel system a very crude clean up almost as effective as a terraclean.
  6. Likes big jon liked this post
  7. #6
    Full Member Rhodie's Avatar
    Oct 2014
    Ossett, W Yorkshire
    31 Post(s)
    Blog Entries
    1
    Engine : 1.9 CDTI 150
    Mileage : 75000
    It all comes down to luck. I had a mate who bought a 6 month old preface 1.9 after having petrol cars all his life. This in fact was his first diesel. Anyway he bought it will a full tank and 2 weeks later filled up from nearly empty with petrol instead of diesel, on his way to see his parents in Basingstoke (this was from Hull by the way). All seemed fine until he stopped around Bedford at services for a coffee, and said that it struggled to start when they wanted to set off, but still drove ok. Carried on to Basingstoke, spent the weekend with parents, thinking he would take the car back to the dealer when he got back to Hull. Dealer phoned him an hour later to say they had found the problem. They drained the tank and changed filters etc but told him if there any lasting damage it would not be covered under warrantee. Couldn't argue with that About 500 miles round trip. He had the car for about 7 years, no problems re fuel whatsoever. Just goes to show how bulletproof these engines are.
    2007 1.9 CDTI Elite hatch 150. 2 x led boot lights, HID's, aux, comfort unit, circular wheels, overhead roof and see through windscreen
  8. Likes big jon liked this post
  9. #7
    West Mids
    The car has now done over 1000 miles since the misfuel. No noticeable changes to performance, no new noises, and the computer thingy shows the last 950 miles on holiday (to and from France from Brum - 2 people plus luggage) at 52.3mpg.
    Thanks for the advice and thoughts. Not sure if I have been lucky, or the companies which advertise misfuel rescue are playing it very safe by saying 'whatever you do don't start the engine if it's over 5% petrol in a tank of diesel'...?
    Anyway, the chap who showed me how to drain the tank, and then did all the wet and smelly work under the filter housing while I turned the key every few seconds to run the pump, is getting a nice bottle of bourbon next week!! The least I can do after saving me £200 or so
  10. Likes Dog_Book liked this post
  11. #8
    West Mids
    And a year and eight thousand miles later everything is still fine
  1. Possible engine damage ford fiesta
    By rob warrington in forum General Chat
    Last Post: 19th January 2013, 22:57
  2. What could be the damage from this...
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2012, 20:03
  3. Faulty thermostat, does it damage the engine ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2011, 07:23
  4. More Damage
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2007, 08:46
  5. Engine flood damage!
    By John Arthurs in forum Engine & Drivetrain
    Last Post: 16th January 2007, 12:35
