Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Pollen Filter
    Regular Member Merick's Avatar
    Mar 2007
    Wigan & Preston
    Default Pollen Filter
    Took my pollen filter out last night to sort out the smell with the Air-Con.. it was minging.. flies, leaves, dust and it was BLACK!! Got my new one today... guess which one it is! lol
    Regular Member vectravirg's Avatar
    Bolton
    How did you take it out/ where is it?
    Mar 2007
    Wigan & Preston
    I'll post some pics at lunch.. (mines a pre facelift by the way, i believe it's different on a facelift??)
    1. Open the bonnet and look at the passenger side next to the windscreen. Where the washer jet is, there should be a kinda flap, there a are two slits.
    2. Pull back the seal and lift the flap (pulling the seal off makes it a little easier to lift the flap)
    3. Locate the two white clips at the top and get your finger underneath it and pull outwards, these break very easily, i've snapped one of them off!
    4. pull the top of the filter towards you then lift it out.
    5.Job done.. reverse the process to put your new one back in.
    Mar 2007
    Wigan & Preston
    I'm not sure if there is a how to on this, if not, i'll gladly write one (with pics!!).
    Bolton
    Cheers, mines also a pre facelift, will have a look after work, think mine will be a similar state to yours and in need of replacement.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    it is the same on a facelift
    Mar 2007
    Wigan & Preston
    Ah, sorry.. it was the thing about the front indicators i was reading the other day that was more difficult on a facelift.
    Mar 2007
    Wigan & Preston
    Quote Originally Posted by vectravirg View Post
    No problem.. I've had the car 10 months and never even thought about changing it.. god knows when it was last changed.. if ever! I had the air con re-gassed and it smelt awful, read somewhere about spraying dettol in the hole behind the pollen filter and it's when i took it out, i saw it and thought "Ewwwwwwwwwwwwwwwwwwwwww".. as a clean freak.. it was a bit of a shock.
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Quote Originally Posted by Merick View Post
    Hi Merick
    GSI3.2 did a how to on this link - I have checked mine (facelift) and the process is the same
    Mar 2007
    Wigan & Preston
    Cheers Neil! I knew i'd forget something.. hope to god i put it in the right way round!!!
  1. Pollen Filter
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2011, 14:11
  2. Pollen Filter
    By themarbleman in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 12:47
  3. Pollen filter
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2010, 14:48
  4. Pollen filter
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2007, 14:11
  5. Pollen Filter.....
    By nabs44 in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2006, 08:51
