Thanks Thanks:  5
Results 1 to 10 of 13
Thread: Rear blinds hook install
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 75000
    Default Rear blinds hook install
    So door cards fitted.
    I have the hooks and reinforcement plates, but I can't see how they fit. Obviously the 2 prongs in the hook locate in the 2 holes in the door frame.
    But how does the plate fit?
    I'm assuming the hook fits on one of the little lugs
    Where do the prongs go?
    Any pointers very much appreciated.
    2007 Signum Design 2.8T
    Teapot TUNED
    Powerfold mirrors, Eibachs & Bilstein B4s, Roof rails
    Administrator plasma's Avatar
    On the Forum
    483 Post(s)
    Engine : 150
    Mileage : 74000
    should be a plastic bit which goes into the door frame
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 75000
    Quote Originally Posted by plasma View Post
    Do you know what that is?
    It only shows plates and hooks:
    Teapot TUNED
    On the Forum
    483 Post(s)
    Engine : 150
    Mileage : 74000
    Got some in the ashtray will take picture tomorrow
  5. Thanks watchman thanked for this post
  6. #5
    Full Member RichM's Avatar
    Bracknell
    62 Post(s)
    Might be wrong but isn’t that metal bit something to do with the sun visor? I certainly don’t have them on my door blinds.
  7. Thanks watchman thanked for this post
  8. #6
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 75000
    Quote Originally Posted by RichM View Post
    I looked through previous posts, and got the part numbers. Must have bought them several years ago.
    It's listed as PLATE,REINFORCEMENT,SUNSHADE,WINDOW,REAR SIDE
    Teapot TUNED
  9. #7
    North West - RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    88 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    haven't got them with my blinds either.
    because........SIGNUM!
  10. Thanks watchman thanked for this post
  11. #8
    Apr 2009
    Leeds
    6 Post(s)
    Engine : Z28NET
    Mileage : 75000
    Quote Originally Posted by bonehead View Post
    So you just have the hook?
    How does it stay in place?
    Teapot TUNED
  12. #9
    Jun 2009
    South Coast
    10 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Pull the rubber down that goes around the top of the door frame. You will see two mounting points with two holes in each.
    One hole is bigger than the other as are the pins on the back of the plastic hook things. Ignore those metal parts as they are not for this job,.
    Line up the first book and use a sharp hobby knife etc to cut the rubbers around the hook as it sits in the frame, don't cut masses off, just enough, as you can always trim it further if beeded.
    Once done do the other one, then repeat for the second door.
    I can post some pics if needed but it really quite an easy task once you see the holes in the frame that are there on all vectra and signum rear doors.
  13. Thanks watchman thanked for this post
  14. #10
    Feb 2015
    Warrington-ish
    88 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
  1. Rear Blinds
    By TrackTiger in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2013, 21:05
  2. rear blinds
    By willoftoon in forum Styling
    Last Post: 27th June 2009, 20:44
  3. Rear Blinds
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2009, 07:50
  4. Rear Blinds for Vec-B
    Last Post: 16th March 2009, 12:11
