Thread: Power steering pump and Steering rack
    May 2018
    South Yorkshire
    Vehicle : Vectra 1.9 CDTI 150
    Engine : 1.9
    Default Power steering pump and Steering rack
    Evening all.
    Long time lurker here but i've decided to post now that I have a pretty substantial issue and I was wondering if you guys can shed any light on it for me.
    The power steering on my 2008 Vectra 1.9 CDTI 150 stopped working the night before I went off on holiday last week. As I was away I booked into Halfords for a free steering check so they could diagnose the problem and they have told me it needs a new Power steering pump and steering rack. They have quoted me £780 for the parts.
    I have brought the car home and out of curiosity wanted to check the power steering fluid and found that the dip-stick on the underside of the cap wasn't even touching the fluid in the well so it was obviously too low. I topped it up but it made no difference to the steering and then half an hour later there was hydraulic fluid all over the driveway so it's pretty obvious that I have got a leak.
    I've now taken the car to the garage that I usually use for any repairs/MOT etc to ask him for a second opinion but I just wanted to put the question to you guys on the forum to ask is it common for the rack and the pump to go together? or is it just a case of you might as well change the rack if you are changing the pump?
    I'll be honest, the car probably isn't worth the money I have been quoted to fix it so I'm currently thinking of either scrapping it or selling for spares & repairs if it is going to be such an expensive job.
    Any help or information you can provide would be much appreciated.
    You should also know I have zero mechanical experience so it's not something I'll be able to do myself.
    Thanks all.
    Administrator plasma's Avatar
    On the Forum
    483 Post(s)
    Engine : 150
    Mileage : 74000
    sounds like the rack seals have gone and is leaking out through the bellows.. check either end if you can and see if thats where its coming from.. A replacement rack (2nd hand) should be too expensive about £60 - £80 ?? and about £60-£100 for someone to change it at a guess
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    34 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    the prices that @plasma gave are the ones that i have heard before... the high price you've got quoted is because they only fit new parts at Halfords... you can't even supply a 2nd hand part for them to fit.. they won't touch it... but take it to a independent garage and they'll fit it for you...
    and yes if the oil leaks out of the powersteering, the pump of it will go especially if it has worked without oil for a while (anywhere from 5 to 15 min.) the pump is a submerged type so it can't handle running dry for too long.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    22 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    If you look on ebay secondhand racks start at £35 delivered...TBH if I were to but one id replace seals etc BUT you can buy a remanufactured one delivered for £100...just an option..
    May 2018
    South Yorkshire
    Engine : 1.9
    Thanks all. Much appreciated.
  1. Replies: 8
    Last Post: 7th September 2015, 22:27
  2. Replies: 1
    Last Post: 19th August 2015, 21:12
  3. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  4. power steering rack
    By steebdon in forum Handling & Braking
    Last Post: 21st January 2010, 16:14
  5. power steering pump..and rack..do they have to be from a 3.2
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 19:48
