Thread: TPMS programming with tech2 guide?
    VIP-Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    11 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Default TPMS programming with tech2 guide?
    Any chance anybody could author a TPMS programming guide for Tech2 or Opcom. My config seems to have vanished, I suspect it could be when I had to change the CIM.
    Ta
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Nothing really needed to program for the TPMS, it lives on LSCAN so ensure all LSCAN configs have TPMS set to "Present" then do module programming and follow the prompts.
    The wheel sensors are self-learning, so once it's programmed up, as long as the light illuminates yellow then goes out on ignition on, and you can see the pressure status in the DIS, it'll eventually get a signal from the sensors and start displaying data. From memory it starts displaying once the wheel speed is greater than 30kph but I've had it pick up from stationary in the past.
    I've only done this with Tech2 so can't comment on opcom.
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Do you need to activate a new sensor?
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Quote Originally Posted by lee gsi View Post
    Nah, fit and forget (on the vec anyway, not sure about the newer kit on the insignia) - ignore what tyre places tell you about having to have it re-learned or recoded.
    They're also not coded to a position either, so you can still rotate your tyres as normal without getting screwy readings.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Year : 2008
    Mileage : 69k
    Mmm it does pick up what sensors go where, i swapped my fronts with my rears after getting new tyres and it showed the front pressures what the rears were if that makes sense, but it corrected its self after a while, i think thats what the wheel arch sensors r for to get the position
    Regular Member nikolat's Avatar
    Nov 2014
    Bosnia and Herzegovina
    Vehicle : SIGNUM 1.9 CDTI 16v (Z19DTH) 2005
    Trim : SIGNUM
    Engine : Z19DTH
    Mileage : 160000
    I have this sensors on my signum, but one sensor is damaged. Where can I get new one? Is there some chinese cheap replacement?
  1. Tech2 programming
    By ianwat23 in forum North East RO Vacant - ARO - Vacant
    Last Post: 26th June 2014, 14:37
  2. tech 2 programming guide
    By neill in forum General Chat
    Last Post: 2nd June 2013, 18:20
  3. help with tech2 programming auto AFL
    By emsedk in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2012, 16:54
  4. Tech2 Programming.
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 20:55
  5. Need help 4 TECH2 Programming
    Last Post: 24th May 2010, 20:51
