Likes Likes:  2
Results 1 to 10 of 11
Thread: Rain sensor
    Regular Member Stevesellars's Avatar
    Nov 2017
    Ingleton
    Engine : 1.9 CDTi 150bhp
    Mileage : 109000
    Default Rain sensor
    Hi gang
    ive had a look canít find anything on here or the net Iíve do a retro fit on rain sensor and auto lights on my Signum 07 the auto lights work find but the r/s is slow to not at all to react to rain or water unless I more the sensor a few MM off the window does anyone know if that a fitting pad to set the distance from sensor to the window?
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    26 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    look it up here it will show all the parts if you select the right bit... and if you type in your cars vin number it'll show all the stuff that your car has gotten from the factory
    Nov 2017
    Ingleton
    Mileage : 109000
    Quote Originally Posted by northpole View Post
    Ive check all the part and there all correct and it all worked correctly just the rain sensor doesnít pickup with unless you throw a bucket of water on it. But it a move it back by 2mm ish it will pick up just a water drop and the more water I put on the faster it goes however soon as I place it back on the window it stops plus on the inside of the mirror cover there two clips thing where the rain sensor bracket is meant to go on! Thatís why I asked if there was some type of ring that meant to go on the window to give the distance and the bracket fixes to that.
    Apr 2016
    Ipswich
    26 Post(s)
    Mileage : 140000
    If there was one it would be in the parts catalogue if it doesn't state it than it isn't needed... maybe you need to use some hot glue and fix it in place originally I think they use 3M window sealer (you can get it in strips) and it can be moulded to hold it at said distance.
    That is if no-one comes up with another fix for it
    Nov 2017
    Ingleton
    Mileage : 109000
    That’s mite not be a bad idea!
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    What does yours even look like? You don’t mention if you retro fitted it the correct way or the cheap way?
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
    Jun 2009
    South Coast
    9 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    mine just fits to the window without anything in between, post a pic of your set up, like how are you fastening it to the windscreen and maybe a pic or two of the sensor itself..
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    191 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    As above. Need to see what kind of install and windscreen you have.
    The rain/light sensor fits into a dedicated housing and is "clamped" to the windscreen via a silicone type "washer" using the inbuilt clamps in the housing.
    If your install is anything less than the "factory" style install, it might explain your problems.
    HTH
    Woody
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  9. Likes nikroc liked this post
  10. #9
    Nov 2017
    Ingleton
    Mileage : 109000
    It’s the full set up is factory wiring loom, factory sensor and window bracket and mirror cover non are new
  11. #10
    May 2012
    191 Post(s)
    Mileage : 131,000
    Post up a pic of the sensor and bracket on your windscreen
  1. Rain Sensor
    By Knight Rider in forum Styling
    Last Post: 5th July 2012, 14:02
  2. rain sensor
    By n8sby in forum Parts for sale
    Last Post: 22nd May 2010, 16:56
