Hi all, bought myself a 2006 signum elite 1.9cdti auto which I'm really pleased with apart from a couple of things!
The EML seems to come and go as it feels at ignition - not for a problem but it doesn't light up when you turn the key, for example (short video):
https://photos.app.goo.gl/6pYjPqZV2ZJKQUor7
Sometimes it's working:
https://photos.app.goo.gl/eFPY1vAiEp5Ar6R89
I've noticed when the EML doesn't work, the spanner light comes on after ignition, and then will come and go as it pleases. Sometimes, when the EML has come on pre starting halfway through a journey the spanner light will also come on. The fault logged on the ECU is:
P0650 - Malfunction Indicator (MI) Control Circuit Open
(04) - Not present
Clearing it stays clear until the EML doesn't come back on again and then that fault is logged again.
The cruise control buttons are also playing up slightly, sometimes the cruise control will work perfectly for miles, sometimes it'll take 2/3 times for it to set (it'll unset itself) and sometimes while you're going along it'll unset itself. CIM logs these faults, again clear while it's all working but after an instance they return:
B3794 - Switch Cruise Control Circuit Malfunction
(08) - Not present
Are thes elikely to be related? I've read some info on here about cleaning the CC contacts which I haven't done yet but will attempt, what about the clocks, could that be related or is it a dry solder joint issue possibly?
TIA!
