has anyone on here used them in thier z20net engines?
i can get a set cheap at work but wondered if they are any good.any experiences welcome
don't bother with them they are gash on these engines if you have tune in them. I destroyed a set in months but i had tuned the t1t$ of mine, ended up using some biofuel plugs as they took the extra heat. If you are running a standard 2.0t engine with maybe an easy tune then go from some NGK
I took plugs out the other night and it has ngks in it so stick with them
Sent from my SM-G930F using Tapatalk
