Thanks Thanks:  10
Likes Likes:  2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Siezed disc screw, HELP!!!!
  1. #11
    Regular Member Teapot's Avatar
    Mar 2010
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    It's probably been rounded off, as it requires a Torx Bit (a T20 size IIRC) to undo it, and not an allen key.
    T30 if my memory hasn't failed.
    I've also had one round off once. I just drilled the top off it with a large drill bit and removed the disk. The thread came out fine with a pair of molegrips. Then bought a new screw for reasssembly.
  2. Thanks Darter thanked for this post
    Likes nikroc liked this post
  3. #12
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    You are correct. It is a T30 size. Just looked in the how2 section for changing discs and pads.
    E20 is the size of the bolts holding the calliper onto the hub.
  4. Thanks Darter thanked for this post
  5. #13
    Dec 2017
    Towcester
    Vehicle : Vectra 1.9 cdti
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Thanks for all the advice guys, I'll let you know which one works.
  6. #14
    Dec 2017
    Towcester
    Trim : Exclusiv
    Engine : Z19DT
    Year : 07
    Hi guys.
    Thanks for all the advice. I got it out fairly easy in the end. I just tapped a screwdriver into it and tapped it round with a hammer.
    Big relief
  7. Likes bonehead liked this post
  1. Disc retaining screw
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 8th September 2016, 00:04
  2. siezed bleed screw
    By OLD DOG NEW TRICKS in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2014, 23:39
  3. disc to hub screw?
    By Billy Mc in forum Suspension, Wheels & Brakes
    Last Post: 13th July 2014, 19:49
  4. Rear calipers siezed
    By tomo610 in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2013, 17:57
  5. 03 2.0 DTI Engine siezed! Whats next for it
    By onehand in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2008, 11:36
