Thread: battery going flat
    May 2007
    worcs
    Default battery going flat
    My 02 Vectra keeps making the battery go flat overnight. Removing fuse number 9 for the BCM stops the battery going flat. Car is completely standard and nothing appears to be staying powered up.
    Any idea`s?
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    Does it say what is powered by that fuse?
    May 2007
    worcs
    It is just for the body control module. Obivousley there are a lot of systems that run through the bcm, so it isn`t this circuit which the draw is on, but the fact the bcm is staying powered up and keeping something on or is being told to stay on . Been through all the normal stuff, such as boot lights, stereo etc, but nothing seems to be working or powered up. Pulling my hair out with this!
    The draw is enough for the car not to start in the morning, and totally dead after 2 days. Battery is new, alternator is charging fine.
    STOKE-ON-TRENT
    I had the same thing with a 2003 Vectra, ended up it was the tailgate latch,
    Regular Member henocsr's Avatar
    rushden
    My 2004 GSi did the same thing a month ago. Found that the glovebox light seems to be permantly live, and with it being of a very cheap looking design, sayed on all the time. Have disconnected it now, and am going to rewire it to have an illuination live
    Derby
    Quote Originally Posted by Dunc View Post
    just been looking through threads for problems on flat batteries. Mine goes flat after around 4 weeks, I recharge and all ok again. Recent service checked alternater and battery - both ok. However did have a problem with the tailgate latch, 'fixed' but maybe the root cause of the problem with the battery. Did you fix your problem with the latch, and if so how?
    STOKE-ON-TRENT
    Quote Originally Posted by Ian L View Post
    Yes. The dealers ajusted the latch and i never had a problem after that
  1. flat battery
    By stanlee in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2011, 18:31
  2. Flat battery
    By mjvalentine in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2008, 21:51
  3. Flat battery, I think
    By Hideous in forum Engine & Drivetrain
    Last Post: 29th December 2007, 20:50
  4. Flat Battery
    By VauxVeteran in forum General Chat
    Last Post: 28th October 2007, 17:26
  5. flat battery
    By LAV6Y in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:47
2004 vectra c going flat
battery going flat on a 02 vectra
battery going flat on my vectra c
vectra c flat battery
