Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 13
Thread: Egr blanking plate
    Apr 2018
    Cornwall
    Vehicle : Signum 1.9cdti
    Engine : 1.9
    Default Egr blanking plate
    Hi is there any links on how to fit a egr blanking plate and wich one I should go for.i have a signum 1.9cdti 120bhp.thanks
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    There are loads of threads on here regarding blanking the EGR. Have a look in the right section or use the search function.
    For example
    https://www.vectra-c.com/forum/showt...ight=Blank+egr
    Apr 2018
    Cornwall
    Engine : 1.9
    Quote Originally Posted by fatfred View Post
    For example
    Thank you for your help
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    For example
    To be fair an EGR blank is a modification and the forum search tool is pants. I usually get best results with google vectra c etc
    Teapot Tuned 245/300
    https://www.vectra-c.com/forum/calendar.php
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    For example
    Its also a fix to a recurring problem.
    Jul 2018
    Hemel Hempstead
    Vehicle : CDTi
    Trim : SRI
    Does this put the EML on on the Z19DTH, as I thought the air flow was monitored, this is my first diesel, so if I'm wrong please let me know
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Yes
    Sep 2014
    uk
    Vehicle : vectra C sri estate automatic
    Trim : sri auto + design auto x 2 1/2
    Engine : 1.9 cdti 150
    Year : 08/07
    Quote Originally Posted by Ash-signum View Post
    Having fitted blanking /restricter plates to our 3 z19dth vectras what i can tell you is you use 2 plates. The one between the inlet manifold and the egr valve has one 9.5 mm hole drilled in the centre of the plate, the one between the egr valve and the inlet pipe from the exhaust has 4 holes drilled in it these are 7mm in diameter i have tried 5mm holes BUT this puts the eml on. The plates drilled or undrilled can be bought on ebay.Forgot to say i just used some gasket sealant instead of the original gaskets and everything is ok.
    Oct 2013
    Derby
    221 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    He wants to fit a blank, if it’s got a hole then it’s not blanked is it.
    Looking through the forum should I’d hope show the best way is 3 plates 1 being on the exhaust manifold which helps stop the cooler from being damaged
    Apr 2008
    West Yorkshire
    The reason why some of the egr "blanking" plates are used is that the ecu has detection algorithm that determines the volume of air consumed and relates that to the maf for air volume metered at the intake. The difference is the air induced into the engine via the egr valve. There is a tolerance built into this but once exceeded various p04xx errors are then flagged if the flow is reduced or there's a wiring / mechanical fault with the egr.
    By fitting a gasket with a 10mm hole, the volume of air from the egr is minimised but still within the measured tolerance of flow detection. This results in 'better running' due to the reduction of the egr inert co2 air whose primary function is to reduce the combustion temperature minimising the production of NOx (as well as less HC soot being recirculated through the inlet steam). However, more oxygen is better 'running' etc.
    Fitting a full blank requires the ecu modification to disable the monitor function, as in 'mapped out'.
    A restriction gasket to 10mm could have been an official 'dealer modification' without the removal of an emission control device in the ecu.
    My old Astra G with the 1.7cdti 80hp engine worked great with a restriction gasket with an 8mm hole in it without any software modifications.
    My v6 cdti doesn't even work with a egr gasket with a restricted hole, so it's not guaranteed to work on all vehicles.
  11. Thanks autov thanked for this post
    Likes autov liked this post
  1. That's Not A Blanking Plate!
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 1st May 2013, 16:19
  2. blanking plate
    By lordreeson in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 12:59
  3. egr blanking plate
    By squiggy4 in forum Engine & Drivetrain
    Last Post: 27th January 2010, 20:55
  4. EGR blanking plate 2.2 dti ?
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2009, 09:19
