Thanks Thanks:  2
Likes Likes:  1
Thread: Steering wheel compatability
    Regular Member Steel's Avatar
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 213,000
    Default Steering wheel compatability
    I know steering wheels have been mentioned on many occasions, but as I was thinking about upgrading to a VXR flat bottom wheel a thread elsewhere made me cautious.
    My preface SRI (CD70 NAV if that makes any difference) has the same scrollers, which I had previously thought meant it was a full can system and I would be able to fit any other wheel with scrollers, but I have seen it mentioned that facelift wheels will still not fit preface.
    Can anyone confirm which is right?
    TIA
    Shaun
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    I think you'll find if it's not got scrollers it's not full can. Some pre face are full can, I think that is the only criteria.
    I'm sure someone will correct me if I'm wrong.
    https://www.vectra-c.com/forum/showt...Steering+wheel
  3. Thanks Steel thanked for this post
  4. #3
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 213,000
    Quote Originally Posted by fatfred View Post
    Thanks Fred, that's what I thought, wouldn't be the first time Vauxhall/Opel had done a mark 1 1/2, I had a Monza which was mark 2 outside and mark 1 inside, so hopefully the fact that mine came with scrollers from the factory means it's full can. I guess the way to confirm it will be the airbag wiring.
  5. #4
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    191 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    There were limited numbers of full canbus cars from late 2004 to early 2005 before they got facelifted.
    Early 2004 cars are pretty much all halfcan unless the car has been modified to full can as some have been including mine.
    You shouldn't have any issues if your wheel with scroller buttons actually work the display and headunit, the biggest issue is the kind of airbag plug, however, as the airbags are usually swapped from the old to the new wheel, I can't see why you would have a problem.
    I would wait for some other members to confirm my comments for you before proceeding however, to be on the "safe side"
    HTH
    Woody's Vx Ice Addons UK/Eire Distributor of the Comfort Unit and Video Accessories from www.PepaS.cz Designed to enhance your Headunit & Display these add in Additional Data and Reversing Camera & Media. NOW INCLUDES FULL Vxr/OPC NEEDLE SWEEP & LIGHTS Also CD70 Aux In & 3 Line Display Updates.
  6. Thanks Steel thanked for this post
  7. #5
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 213,000
    Quote Originally Posted by Woody View Post
    HTH
    Thanks Woody, that does sound perfectly feasible, mine was registered in April 2005 so would be a pretty late pre faceluft although I don't know just when it was built. My mate has a 2005 Signum, also with scrollers but his is a 2.0DTI not a cdti.
    I know some people on here know these things inside out, but so far you have confirmed what I thought and the post I saw that sowed the seed of doubt if fading away. Thanks again.
  8. #6
    Sheffield
    Trim : SRI CDTI NAV
    Mileage : 213,000
    Just in case anyone is interested, I bit the bullet and got a complete facelift SRI steering wheel and airbag from fleabay.
    It fits and works perfectly, although the wiring plugs for the scrollers are different it is a flour pin fitting and interchanges, but to use your original scrollers you wold have to change all the wiring inside the steering wheel.
    You also have to use the facelift airbag as the wheel is a slightly different shape and although the airbag wiring is the opposite was around it works perfectly.
    The wheel is slightly smaller with thumb grips and a more sporty feel, very happy!
  9. Likes fatfred liked this post
  10. #7
    Jan 2018
    Pt
    Vehicle : C
    Trim : Gts
    Engine : 1.9
    Year : 06
    Btw the steering wheel from a Astra h Sri fits in our vectra without any mod?
    Enviado do meu PRA-LX1 através do Tapatalk
  1. Power steering gone! Steering wheel on dash with explanation mark
    By IRvectra786 in forum Engine & Drivetrain
    Last Post: 17th August 2013, 12:30
  2. Vectra c steering rack dashboard steering wheel
    By Martinlw in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2013, 23:05
  3. For Sale: Sri facelift steering wheel c/w steering wheel controls
    By andy.l in forum Parts for sale
    Last Post: 3rd February 2013, 16:08
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Replies: 6
    Last Post: 13th March 2011, 10:47
