Likes Likes:  1
Results 1 to 10 of 17
Thread: Vectra noob
    Apr 2018
    Stockport
    Trim : Energy
    Engine : 2.0 DTI
    Default Vectra noob
    Hi all. I've inherited a 2004 Vectra - 2.0 DTI Energy model recently and I'm looking at making some improvements to keep it running as long is possible/worthwhile.
    I figured I'd start with the MOT advisories and go from there...
    • 1. Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    • 2. Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    • 3. Rear Brake pad(s) wearing thin (3.5.1g)
    • 4. Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    • 5. Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
    • 6. Nearside Headlamp deteriorated but light output not reduced (1.7.5a)
    • 7. Offside Headlamp deteriorated but light output not reduced (1.7.5a)
    • 8. Nearside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
    • 9. Offside Front Anti-roll bar linkage has slight play in a ball joint (2.4.G.2)
    • 10. Front Sub-frame corroded but not seriously weakened (2.4.G.1)
    • 11. Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
    • 12. Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
    Rear tyre has been replaced so number 12 done, but car definitely needs tracking/balancing.
    I've ordered new drop links for the front - will that cure 8&9?
    I've ordered new headlight assemblies rather than try to buff/repair the current ones as the nearside one also has no seal on the back and has condensation inside - and I got a good price for a set, so that's 6&7 sorted... looking at adjusting the headlight height too so I can actually see some of the road.
    Is it time for new pads and discs all around according to 1-5?
    Also, the car hasn't been serviced in probably 10 years... not even an oil filter change from what I know. Where is best to get a service done, if it's worth it?
    Sorry about the long 1st post, but hopefully you can all offer a little help/advice
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    26 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Mileage : 140000
    they are all small things....
    oil can be done at any garage they'll give it the right oil... but i would drop in a flushing oil before bringing it in for the oil service... or diy it it's not rocket science...
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    27 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 231,000
    As above. Those are all small problems. Routine stuff. I'd do a couple of oil changes in quick succession, if I were you. Brakes are cheap - droplinks too.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Apr 2018
    Stockport
    Trim : Energy
    Engine : 2.0 DTI
    Quote Originally Posted by northpole View Post
    Quote Originally Posted by GSiFan View Post
    Paul
    Cheers both. So all worth doing then!?
    Can I/do I need to do anything about corroded sub-frame?
    Also, whilst I'm thinking of it. The cruise control no longer works. Is this because the service light and amber engine management light are on? Definitely used to work...
    27 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 231,000
    Sand back any rust that can be seen. Then use some rust neutraliser. Prime. Paint.
    Paul
    Regular Member any-mgzt's Avatar
    cheshire
    9 Post(s)
    Trim : basic
    Engine : Z19DT
    I would find out why the check emgine light is on before doing anything else.
    But as said above all simple things a sunday morning session should see put right.
    Sent from my SM-N910F using Tapatalk
    Apr 2018
    Stockport
    Trim : Energy
    Engine : 2.0 DTI
    Quote Originally Posted by any-mgzt View Post
    Guessing I need a diagnostics check for that?
    What's best (easiest to use) OBD2 to get?
    cheshire
    9 Post(s)
    Trim : basic
    Engine : Z19DT
    Quote Originally Posted by KielCC View Post
    I have tech2 can do a diagnostic check for you. Where in Stockport are you?
    Feb 2018
    MANCHESTER
    Vehicle : Vectra C Facelift
    Engine : Z18XER
    Mileage : 84000
    You can also use the pedal test which will flash up the fault codes. As long as you can count, you can then lookup what the codes mean. Not a substitute for a tech2 but will give you a poke in the right direction.
    https://www.vectra-c.com/forum/showt...-any-Equipment
    Also, look at AutoVaux for your brakes. I was quoted something ridiculous by Vauxhall to do my discs and pads, got the parts for next to nothing from Autovaux - www.autovaux.co.uk - just need to find time to fit them now!
    Apr 2016
    Ipswich
    26 Post(s)
    Mileage : 140000
    if you have a andriod phone and a ELM327 BT dongle (version 1.4 or higher) you can use that and this app or this one... the first one will erase the engine codes not the rest the second will show you everything but unless you buy it won't erase anything... but it will give you the right codes... i have been using both to find engine problems and successfully sorted them out.
  1. Afternoon, vectra c noob here
    By Zedsdead in forum Introduce yourself.
    Last Post: 14th November 2015, 18:44
  2. Attention Vectra noob just joined
    By pyromyst in forum Introduce yourself.
    Last Post: 24th March 2014, 21:48
  3. Noob with a 2005 2.2 SRI Vectra
    By calibra_se8 in forum Introduce yourself.
    Last Post: 12th July 2011, 10:41
  4. noob here
    By Al 22 dti in forum Introduce yourself.
    Last Post: 15th March 2011, 11:01
  5. Newbie Noob, Vectra 150 Nav
    By Barker.Vectra.Sri in forum Introduce yourself.
    Last Post: 17th December 2009, 01:55
