Thread: Possible Engine Blown Help Needed
    Regular Member rickyroo's Avatar
    shropshire
    Default Possible Engine Blown Help Needed
    Had me 2.0t serviced last thursday and looked at "again" regarding the backfiring issue told again cannot find fault.
    My misses drove the car yesterday to pick me up from airport and total power loss.
    I drove it back barely.
    You get no respeonsivness from the throttle pedal in 1st 2nd 3rd feels like your trying to start the car in 5th gear.
    Engine management light up.
    Vx say fault code is Maf sensor.
    They changed me sensor and noticed also that plug gap was 1.5mm which I told them to change to 1mm on it's service which they hadn't.
    Vx Engineer test drove it this morning said it was fine, took it out again as I arrived at the garage 1630 ish by 1800 he still wasn't back then manager came out and spoke with me saying it had catastrophicly failed upon the engineer, and they think the engines shot.
    Oooh whats that shock horror it's only just out of warrenty and now you believe theirs a fault.
    Got to wait until vx direct get back to them tommorow to find out whether they will pay out otherwise it's me again with a bill for roughly 4.5k.
    How easy is it to get piston's to fail or boost rings.
    What about blow holes in pistons.
    Who ever had the car before I bought it got rid of it for a reason now I know why.
    The previous owner has definately had the turbo out for the reason's below, what else could cause my engine to fail?
    recirculation valve spring was missing I replaced.
    Securing bolts upon turbo housing x2 connecting to downpipe missing.
    After market release paste upon turbo housing.
    Inlet manifold from turbo gasket perished, and also carboard not oem.
    Whats the common cause of piston failure?
    Really am worried now
    a) got to pay for the repairs.
    b) got to pay for a car cannot drive
    c) gutted might not be able to come to Pvs, well at leased not in the ill veccy.
    piston failure is caused by either running too hot..poor mixture would do that.. or poor oil spray cooling underneath the piston..
    if the piston has melted, then i'd say it's deffo goosed and it'll need a rebore or clean up the alloy in the bores..
    time to hunt for a new engine, as it sounds like it's been well played with..
    Jul 2006
    Mexico
    Sounds like the Vx personal did´t check the oil or coolant of you car mate.
    Would VX assume some responsability, I mean they were testing it when that happened right?
    you might be able to say it was them pushing it hard, but as the engine has had modifications, i think you'll be on very dodgy ground..if you're lucky they'll meet you 1/2 way..
    shropshire
    Spoke to vx today they say not engine fault, well to honest they don't know whats up with it went in with maf sensor fault and whilst it's been in the garage they have had you will be shocked at this answer like me "43" different fault codes and they don't know whats the fault??????
    I'd say 90% ecu f**ked
    Jul 2006
    Mexico
    Hope they find the fault soon, and lets hope it´s something not too expensive.
    shropshire
    you and me both mate thinking or hoping vx dealer will admitt cannot find fault and exchange me motor vxr would be nice
  1. engine temp help needed
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 13:23
  2. Blown turbo destroys engine!!
    By stiffler4141 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 08:39
  3. Blown turbo advice needed !!
    By andymcniven in forum Engine & Drivetrain
    Last Post: 14th May 2009, 20:50
  4. Blown up Engine
    By mooj in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2007, 07:51
  5. nissan engine blown
    By nev-vec in forum General Chat
    Last Post: 3rd April 2007, 18:39
