Results 1 to 3 of 3
Thread: DAB Windscreen Aerial
    Dec 2012
    Devon
    Default DAB Windscreen Aerial
    Morning, I've had a DAB stereo and internal windscreen aerial for awhile with no issues on reception. Last week I need a new windscreen due to a chip becoming a crack, and had to remove the windscreen aerial during fitting of the new windscreen. I used a stanley blade and it all came off in one piece no cracks or tears etc
    When going back on the aerial had def lost some of its stickiness but went up okay and hasn't come away from the windscreen since, but reception has been really rubbish since, does anyone know if there are there any glues or solvents I could try and use to resurrect my aerial or should I bite the bullet and buy a new one?
    Regular Member fatfred's Avatar
    Dec 2013
    Bristol
    15 Post(s)
    Vehicle : Insignia
    Engine : 1.6D
    Year : 2018
    Mileage : 1 hundred
    Whether it is stuck firmly or not shouldn't alter the reception. When I tried one I use insulation tape on the back of the aerial to fix it to allow me to take it back 'unused'. It sounds as if you may have damaged the aerial taking it off.
    North West - RO bonehead's Avatar
    Feb 2015
    Warrington-ish
    115 Post(s)
    2 Thread(s)
    Trim : VXR!
    Engine : Z19DTH+
    Year : 57
    check the earth strap to the pillar.
    because........SIGNUM!
  1. Replies: 7
    Last Post: 4th February 2017, 18:31
  2. New aerial seal? Rear windscreen freezing on inside
    By dougie89 in forum Bodywork & Interior
    Last Post: 18th January 2015, 17:58
  3. Windscreen
    By gipps in forum Styling
    Last Post: 20th November 2006, 00:31
